Wanting mood lights in my Cali !
N
ndp-camper
Colchester
T6.1 Ocean 199 4Motion
Hi probably not a priority in my newly purchased 2014 Cali but I need some advice !!
I would like some blue mood lights at the bottom of the fridge / hob unit , I have found a company who will make them up ( Aten Lighting ) they will supply a strip made up with a remote switch ready to plug in so my question is what plug to have on the cable a 12 volt into what I would call a cigarette lighter or the 2 pin socket with 150 watts on it under a flap both as you will all know down the side of the unit
Hope that makes sense !
Cheers Neil
I don't have an SE, but I think you will find the 150w socket is 240v fed from an inverter from the leisure batteries.
I would consider hardwiring the lights into the 12v circuit than using up the cigar-lighter socket.
I have some battery powered LED Campervan lights. Installed in November and still on the same battery set.
Sorry pic isn’t the best
46097
I use battery powered fairy lights too,
Some of the powered led strips are too bright and give off a harsh light
I use LED battery tea light candles. They flicker just like real candles. Cheap and last for ages.
We also use LED fairy lights, the batteries last for ages
I tried to dodge the battery LEDs and source some USB powered. Couldn’t find what I was looking for.
I’ve been impressed with the battery version and how long they last
Cheers thanks
We also use them as a warning to our 3 year old. I put him to bed and remind him, any messing and the Campervan lights will be turned off.
Sometimes works ;)
