How many miles and what sort of driving/milage per journey?I have a Oct 22 Ocean, today a yellow warning light came on which the manual tells me is 'emissions-relevant fault'
Any ideas what to do?
Diesels don't like short runs as they are unable to complete a DPF, Diesel Particulate Filter, regeneration to burn off the accumulated particulates. I would suggest you use VW Assistance, part of your 3 yr warranty. This is run by the AA, you should have the contact number. Phone them and ask for a VW Assistance Technician, not the normal AA technician. They can read the codes and if it is the DPF force a regeneration. If it is not the DPF then they have priority access to the local VW Dealership.Mileage is low, less than 4k.
Generally use for a few trips away so far and daily for a very short commute to work (couple of miles).
Today was the longest run in a while about 120 miles.
Our T6 will perform the automatic DPF regeneration even when driving at relatively low speeds with stops and starts at traffic lights etc. If it starts the process while driving around town, which is quite normal for us in London, I just let it complete when parked up before turning the engine off. It easy to tell when complete as the revs drop back down again. Maybe the OP is not letting this happen on short trips.For a DPF regeneration to take place automatically the vehicle should have in excess of a 1/4 tank of fuel, be upto temperature and with at least 20 minutes running with revs in excess of 2000/min.
There seems to be a difference in when regenerations take place between the different engines. I am never able to detect when a regeneration takes place. T6 owners mention the rev rise and engine fans full on . T6.1 , seeing as it uses more Adblue might be different.Our T6 will perform the automatic DPF regeneration even when driving at relatively low speeds with stops and starts at traffic lights etc. If it starts the process while driving around town, which is quite normal for us in London, I just let it complete when parked up before turning the engine off. It easy to tell when complete as the revs drop back down again. Maybe the OP is not letting this happen on short trips.
I thought your instructions applied when the DPF warning light is on. Please correct me if I have misunderstood.
I don't know. Depends on what the Diagnostic Codes show. If they are DPF related then a long run and allowing a regeneration to complete will fix it.Thanks for the responses. So taking the van for a longer run won't sort the problem now? I need a technician to reset the light, is that correct
OK thanks, worth a try first thenI don't know. Depends on what the Diagnostic Codes show. If they are DPF related then a long run and allowing a regeneration to complete will fix it.
To add to this, it could of course be a faulty DPF sensor, which a dealer can diagnose. As a first step I would try the VW recommendation on the link below, which is what @WelshGas suggested. I would try and use a dual carriageway/motorway if possible where you can keep the rev range constant by selecting manual mode.I don't know. Depends on what the Diagnostic Codes show. If they are DPF related then a long run and allowing a regeneration to complete will fix it.
AKA drive it like you stole it or for those more mechanically sympathetic, if you find you have parked, switched off and interrupted a regeneration, restart and drive about with the gearbox in 3rd or 4th or dsg held in manual 3 or 4 to keep revs around 2500.An Italian tune up every now and again will help prevent issues.
From trying the wait for the regen to complete be prepared for a long wait as it may only just have started the regen process.Firstly thanks to @WelshGas and others for the advice.
The fix (as I had done the long runout yesterday) was a software update from the VW technician, the problem was the DPF and the light didn't go out until he did the software update, which apparently would have required a visit to the dealer at some point as it was 'field campaign' so that saved me a job.
His advice going forward is that I don't switch of the engine if the regen is happening as I pull up on driveway, every day is a school day. As pointed out by @Kayleigh in their post.
Very impressed with the service from VW assist.
No longer free £4.19 .For those that aren’t aware there‘s a free android app called ‘VAGDPF’ downloadable from the google play store which when paired with a cheapo bluetooth OBDII scanner (left permanently plugged in) will give you real time ‘graphical’ information on what’s going on with your dpf regenerations. (Yes all this information can be pulled from Carly/VCDS etc but you have to go looking for all the relevant data and not very practical when driving!)
Takes all the guesswork out of it and you very quickly see the pattern for how the regenerations work and more importantly when you either need to extend your journey or actively go for a dual carriageway spin to let the regen finish. Can’t recommend it enough for removing all dpf related stress!. If you’re Apple IOS just dig out an old android phone from your kitchen drawer and leave it permanently in the van just for the vagdpf app (no sim required)
I use the VGATE obd2 but loads of choices out there
a few snapshots from the app…
View attachment 109163View attachment 109164
I reckon most California owners can stump that upNo longer free £4.19 .
Judging by some posts I'm not so sure.I reckon most California owners can stump that up
