BigPritch
Hi Guys,
2007 T5.
The level sensor on the water (fresh) has come away completely (no can't fix it..), so am getting a flashing on the control panel.
Should I disconnect it at the fitting, or is there another way of stopping it trying to read/record flashing ?
Water is working ok, so no issue there.
The 'stem' that attaches to the sensors, has just worn away completely and I think needs replacing altogether...yes probably a garage job.
I can always unscrew the hatch to see levels, so not a major issue, just want the flashing to stop on the control panel......if I can ?
Appreciate any guidance, particularly whether I should disconnect altogether, so as not to drain any of the LB.
We're away for 6 nights off grid next week.
2007 T5.
