water pump blowing fuse instantly
nclarke8
nclarke8
T5 SE 180
I think my water pump has had enough, just tried the pump after filling the tank with sterilising solution and no water from tap and no noise from pump. Last year it took a few times on the tap and then it worked,no luck this time.
Fuse blows instantly. Disconnected pump and opening tap doesn't blow fuse so definitely the pump. Opened tank cover with wooden stick and hammer,its more than hand tight ! The impellor can be turned by hand but not really very easily so can only assume its dried out too much over winter.
There aren't many posts that I can find so am I just unlucky ??
I changed mine a couple of years ago
Alandval
David Ashcroft
David Ashcroft
David Ashcroft
Azteccamper
Janno
Janno
