jliungman
Hi!
I thought I had frozen my fresh water pump during my first winter of ownership in Scandinavia. I was not getting any water, basically. Checked the fuses (OMG just finding those was major carnage, and figuring out what fuse was what... wow). Managed to open the water tank (THAT was a battle, including designing a home-made tool), got the pump out, then connected it directly to a 12 V battery. It then runs just fine. And it pumps water properly (got wet trying THAT).
I now assumed a glitch where the pump is connected to the power supply (little plug on top of tank, supplied by the relay in the tap), but this cable shows the normal 12 point something volts when I open the tap (no pump connected), so the relay seems ok. Tried bypassing the plug completely. Yet the pump still does not run from that power source.
*add major head-scratching here and a big mug of coffee*
So:
a) the pump itself is ok with a reliable power source
b) I can measure voltage from the supply cable when the pump is disconnected and tap is on
c) I measure very low voltage in the supply (0.5 V) as soon as I connect the pump, and the pump does not run.
Is it possible that the relay (micro switch?) is semi-glitchy, providing the voltage when there is no load, but with a poor connection such that it cannot power the pump? In other words, a voltage drop under load, due to high resistance. I seem to hear the pump ticking and sort of almost starting to turn. If I did not know that the pump runs fine with a proper 12V power supply, I might have suspected that it has shorted out (but that SHOULD have blown fuses in my experience).
Any ideas, all you clever people out there? I know 12 volt systems from boats, but only ever had pressure-sensitive pumps, not taps with a relay.
John
So:
John
