![mountainman](/data/avatars/m/0/380.jpg?1611425652)
mountainman
- Messages
- 200
- Vehicle
- T5 SE 180
I have had a good look through the water pump issues but my problems seems to be electrical and I'm stuck. I have checked the fuse and I have checked the tap microswitch with a multi meter and both seem OK. I have then checked for power at the pump and seem to have .5v whether the tap is on or off, definitely not 12 v. I have checked the power at the fuse and get 12v as expected. So if the fuse is OK, the tap switch is OK, then something is happening in between. Is there a relay involved? I assume there is as the micro switch probably isn't up to the current required for the pump? Also the wiring colours leaving the tap are different to those arriving at the pump.
There seem to be a number of little coloured boxes next to the water pump fuse under the passenger seat. Relays?
Rather disturbingly I found a semi attached piece of yellow wire which seems to have come adrift. Only the main dealer has been in here so god knows what that's about. Pic attached.
But yes, Help!! Please![20230828_114412.jpg 20230828_114412.jpg](https://vwcaliforniaclub.com/data/attachments/112/112051-0597efb7df46c364f5254208ec27d500.jpg)
