Water tap
Juzza
Juzza
London
Tap Issue
Hi I have a lovely 67 reg Cali Ocean that I have had for 1 1/2 years
The water pump for the sink sounds like it is working, but the water isn’t pumped to the sink. Instead seems to be pumped back into the water tank
Any ideas? Thanks
Welcome :welcome
If the tap switches the pump on then which it appears to do as you can hear it ok then May be an air lock or the pump has become dislodged from its usual place in the tank corner and may be sitting out of the water or become detached from the connecting pipe to the tap.
I know this sounds difficult but disconnect the tap electrical connection under the sink, open the tap and blow hard down the tap outlet. If the pump is sitting in the water and connected you should hear air bubbling into the tank and there will be some resistance to your blowing.
Reconnect the electrical connection and the pump should prime and start pumping.
If there is no resistance when you blow then the pump is either out of the water or the pump has come off the connecting pipe inside the tank.
This may fit with your observation that you think the pump is just circulating water in the tank
The access hatch for the tank is in the wardrobe .
More details here
correct placement of pump in tank and white connection pipe.
Welcome :welcome
More details here
Thanks for your advice. Spot on the tube had become disconnected from the pump. Reduced and everything working perfectly. Although I’m not sure I put the pump back in the right place how can you tell?
Thanks so much. Saved me from expensive trip to VW
Justin
Apologies for spell check. ‘Reduced’ should read ‘reconnected’ ; ie the pipe
Glad it helped.
The pump is located in this side of tank
And the floor of the tank has a couple of lugs in it to stop the pump drifting about although a good thump into a pothole or speed bump May dislodge it.
So long as you get water out of the tap when you want I wouldn’t be too fussed about where the pump was unless you can hear it “clonking” about in the tank above the other noises in the “Cali” sound track
:thumb
Thanks to @Cali-61-180-SE for original images
Glad it helped.
:thumb
Thanks again, that is so helpful
