![Georgeo](/data/avatars/m/18/18610.jpg?1711007835)
Georgeo
If you remove it there should be a VW part number on the inside.Just found a large crack on the side of the rear light cluster. So need a replacement. But which version. It is a 2019 Beach. See image. Any help appreciated. Also I don’t think you can get the Lens alone. Is this correct?
Just put some clear tape on. Will keep water out until replaced.Thanks will do. Worried it will come apart but I guess a bit of glue will hold it.
