2into1
Née T4WFA. Now without Cali :(
I'm hoping someone with a van with the exact or similar spec in the title can help me.
My van was originally registered in Germany and, as is typical with imports, when it was registered in the UK, not all the usual fields and databases were populated.
So when for eg I need an oil filter, the reg number can't be used to identify the right part. Although I offer the chassis number, many parts suppliers and smaller garages seem flummoxed.
So I'm hoping if I can learn the reg number (by direct message for security) of a normal UK registered van of the same spec / age, I'll be able to use that when ordering parts (obviously those that will be common to my LHD van)
So, if you have a rhd 2006 (or 7) 130hp manual Cali, with a BNZ engine with the dpf, would you be so kind to share your reg with me?
If you can get close to that spec, I'd still be very grateful if you could help.
Thanks.
Thanks.
