Dual Mass Flywheel (DMF)
Ouch, but at least you're mobile again.:thumb
That should be one Part less to worry about now :thumb
Glad It's been sorted
Alan
If that part had been greased from the factory it would have lasted a lot lot longer. Some peoples seem to have gone at a lot lower mileage. 125k miles for component like this to fail on a laughingly called "premium brand" is pathetic. On some commercially used T5s thats only a couple of years.
What you need is the cv joints to fail more often. Then the drive shaft splines would get lubed.
Well finally had DMF and clutch replaced by a local garage, the parts are manufactured by LUK, who also make them for VW.
John
