Tony Beretta
Hi all, the tap in my new cali is loose. It has been like that since handover. I tried to screw it or push it with not much force with no results. Any ideas/tips?
That is what I might do if I can not fix it myself. The tap does not seem to be broken. I think is just that it is not properly attached.
According to this it seems to be a push fit.That is what I might do if I can not fix it myself. The tap does not seem to be broken. I think is just that it is not properly attached.
Same as mine.OK, my problem was that part 7 in the graph separated into two pieces. The pipe disconnected from the part with the ball valve and switch.
