The problem with those is, the Condensation is still present, just not on the windscreen. So it will be on the inside of the body panels behind the trim or at the back of the kitchen cupboards.No experience of those brands, but we have a fairly inexpensive one from Just Kampers which is fab. Silver, insulated, comes in 3 parts with Velcro down the sides, tie downs to door handles. Cosy and greatly reduces condensation during winter camping.
That may be the case, though I've not been aware of damp in cupboards etc. We do use the heater but don't have windows open at night in the deep midwinter. The van is open a lot during the day though. The benefit to me of the exterior cover is that it's easy to put on compared to faffing with the blinds with the front seats turned round and I don't have to do my back in wiping off the wet windscreen inside with a towel before moving off in the morning! I was just trying to be helpful since someone asked and I had used one.The problem with those is, the Condensation is still present, just not on the windscreen. So it will be on the inside of the body panels behind the trim or at the back of the kitchen cupboards.
To AVOID any condensation you need adequate ventilation, even in the depths of winter which is where the Parking Heater comes into its own.![]()
Just a warning to the OP. We ALL breath out water vapour, a substantial amount, and it has to go somewhere. If it's not condensing on the windscreen and not going out via some ventilation opening then it's condensing somewhere - that's just pure physics. You may not have found it, but it's there.That may be the case, though I've not been aware of damp in cupboards etc. We do use the heater but don't have windows open at night in the deep midwinter. The van is open a lot during the day though. The benefit to me of the exterior cover is that it's easy to put on compared to faffing with the blinds with the front seats turned round and I don't have to do my back in wiping off the wet windscreen inside with a towel before moving off in the morning! I was just trying to be helpful since someone asked and I had used one.
With 5 of us sleeping in the van we get a fair amount of condensation in winter even with good ventilation and heater going. Just the physics of the amount on breath! It's often freezes on the rear bumper once it's dribbled out of the tailgate!Just a warning to the OP. We ALL breath out water vapour, a substantial amount, and it has to go somewhere. If it's not condensing on the windscreen and not going out via some ventilation opening then it's condensing somewhere - that's just pure physics. You may not have found it, but it's there.
If the Windscreen is thermally insulated and the interior warmer, leading to a lower Relative Humidity, it won't alter the Total Mass of Water held in suspension, and unless that is reduced by adequate ventilation then you will end up with a greater Air Temperature to Body Panel/ Non-Insulated Window difference and hence condensation.Well the physics of it is all to do with the temperature you keep the van at and the relative humidity. We breath out (at rest) somewhere between 7-20ml/hr of water just through respiration depending on air temperature, relative humidity and minute ventilation. If you ventilate the van with cold moist air you may get more condensation forming. Keep the van warm then the RH will remain lower. Obviously at any warm air/ cold surface interface the air at that point may reach saturation point = condensation. By insulating the front window youre not necessarily going to get extra condensation elsewhere but its possible. It might just keep the van warmer.
If you have Window Deflectors fitted, you can drop the front windows by 1 or 2 cms, cannot be seen from outside, and this improves ventilation and decreases the condensation.I found the problem with the external one, I have the JK one, is that it gets wet....then you have this great big wet thing to store in the van.
I have started reusing the ones that came with the van, Doesn't take long to fix.
There is some condensation, so I pull them off , trying not to touch the windscreen, then have on window cleaner thing( like window cleaners use) and a cloth to catch all the water.
Thén drive with aircon on.
They also makes the van look less conspicuously a camper van if you are parked up off site
stop going on about physics and just say which ones best. we all know about condensation for crying out loud I get condensation in my well ventilated house
Ha ha some of these threads get you like that, don't they! My JK one is great. I suspect they're all pretty good!!!stop going on about physics and just say which ones best. we all know about condensation for crying out loud I get condensation in my well ventilated house
yes....can you recommend an external cover for my 4 bedroom house?Ha ha some of these threads get you like that, don't they! My JK one is great. I suspect they're all pretty good!!!
Isn't there some artist who's always wrapping stuff? I could never see the point but if that's your bag .....yes....can you recommend an external cover for my 4 bedroom house?
Found the link:don't think they're artists but your right. you can vinyl wrap anything. I work on the railway and we payed a company to wrap a full train in tour de France stuff. we called it the yellow peril . not the flying banana
