We are currently in Cornwall enjoying the summer downpours! Totally agree the Galli design is flawed. Water pools on the tunnel as it's too flat . I've had to strap ours down to prevent it happening. Had this happen many times now and a bit fed up with it.
We only bother connecting when it's raining. Very handy for keeping the grass dry where you step out of the van.On the last two occasions that we have used our Galli Low we didn't bother to use the connecting tunnel. The awning is vast and the tunnel is a bit of a faff to connect so is it really worth bothering to connect it? Just asking.
I'm with you on the design flaw of the Vango Galli Low - I spent most of this morning removing large pools of water from the awning tunnel. Completely fed up with it.We are currently in Cornwall enjoying the summer downpours! Totally agree the Galli design is flawed. Water pools on the tunnel as it's too flat . I've had to strap ours down to prevent it happening. Had this happen many times now and a bit fed up with it.
Mines being picked up on Tuesday to go back to vango.I'm with you on the design flaw of the Vango Galli Low - I spent most of this morning removing large pools of water from the awning tunnel. Completely fed up with it.
I like your solution, but we shouldn't put up with this. Has anyone had any communication with Vango on the issue? Or another solution... I think they changed the design for 2017.
Gaffer tape.Oh, one more point, the Galli has a large mesh vent at the top of the rear wall, with no way of closing it off. The wind blows through nicely on cold winter camping trips!![]()
Hi anyone had success in getting vango to change theirs if found to flood?
We’ve just had a nightmare with ours this weekend, in pouring rain we were alerted to crashing at 04:30 am. The main body had succumbed to huge pools of water collecting, this caused the rear section to collapse and the water poured in through the vent.
Hasten to add many personal possessions including electrical goods ruined.
We paid a lot of money for this in November and this is the first chance we have had to use it. I’m pretty appalled and I will be looking for resolution from vango about this as it seems we are not alone in Cali 2 problems!
I notice your Vango is nice and level on the floor, what’s your secret as mine always end up raising an inch or so where the vango writing is on that end......maybe I’m trying to pull it all to tight from the van. Also is it possible to drive away with it connected to the porch? Or would this be a 3 persons job.![]()
Our Kela connected to our van with a massive porch area without side panels.
Thanks so much what a great help in detail, I have screen shot this for reference for when I’m out next. Safe travels1. Make sure the awning legs are fully extended and perpendicular to the front of the wind out.
2. Peg the groundsheet to the awning leg feet.
3. Pull the groundsheet tight and peg at rear.
4. Attach awning to the front of the wind out.
5. Peg out front of awning keeping adjusters slack.
6. Peg out rear of awning tight to front.
7. Inflate rear arch to full pressure.
8. Inflate front arch to full pressure.
9. Peg out arch feet, and two rear points.
10. Insert roof support
11. Peg out rear straps and 4 guys.
12. Wind in the wind out to fully tension.
13. Tighten porch adjusters.
Method has been developed and refined over a years' near continuous use and I continue to refine.
Detaching for driving away is easy and a one minute 1 person job.
1. Slacken wind out.
2. Remove kador.
3. Unpeg and roll in porch.
4. Wind in wind out.
