Cali ocean single socket
glen
glen
Morpeth, Northumberland, UK
T6 Ocean 204 4Motion
Hi. Is it ok to fit 4 gang extension socket to the Cali 3 pin socket. Say kettle/ laptop/ toaster? You would think that they would at least fit a double socket as standard. Look forward to your thoughts :thumb Glen
Yes fit a 4 gang or 6 gang or 10 gang extension BUT remember you have a 10amp breaker, so 2000w max input from all appliances
A lot to put through a socket, plus whatever cable and campsite bollard that you are connected to. Dropping the campsite into total darkness because you wanted a cup of tea is not the best way to find friends :shocked
Toaster? Whats wrong with a ridge monkey or one of the cheap wire rack things that sit on the gas hob and give you brilliant toast in about 30 seconds flat? (o rset the van on fire if you pop to the site loo's and forget but then that's another question).
