Looks lovelyWin Green Wiltshire (Cranborne Chase) 1 degree, lovey winter afternoon
Wow what a difference in weather today. In Cambridgeshire it peed down all day and was grey and gruesome. Glad you had a nice day and thanks for the picsPlaying in the New Forest todayView attachment 28991
Wild or semi-domesticated piggies at 3200 ft in the Aspromonte National Park.
38*12'10" N; 16*1'17" E
Pork chops for dinner?
That is a nice way to take the bike. I guess some modifications must have been done to the van to handle that? Where did you get the bike-rack? I wonder if it could take my old K1100RS.T6 L2H3 150 HP TSI. 12000 km since april 2017. Average fuelconsumption 11L/100km fully loaded (with motorcycle)
View attachment 29712 View attachment 29715 View attachment 29716 View attachment 29717
I ordered this rack from the Reimo catalogue.
You need the universal base construction 1400 mm X 800 mm (there is also a 600 mm version):
https://www.reimo.com/en/46322-cate_rear_carrier_frame_800_mm/
and the base plates for the VW Transporter (T5 is the same as T6):
https://www.reimo.com/en/46325-cate_adapter_vw_t5/
A tow bar is not necessarry but when ordering the rack you have to specify if you have one.
The rack can take 250 kg and has a TÜV approval. My BMW's weight is 220 kg.
The aluminium plates on top are made by a local workshop but you can order them also in Germany:
http://www.cate-vertrieb.de/index2.htm
I ordered my T6 with fortified rear suspension as an option from factory
but this can help also a bit:
https://www.mad-vertrieb.de/niveaufedern2/volkswagen/t6/vw-transporter-typ-t6-baujahr-2015-1.html
When the rack is not on the van you can hardly see the adapterplates.
Regards,
DirK;
New wheels? 20"? Really nice. I still have the bland standard 17" alloys, can't decide if I should go up to larger wheels and lowering or higher with fatter tires for offroad.View attachment 29767 Woke up to white out this weekend in Buxton. Good spot for camping at the Royal Oak pub a few miles out of Buxton. Nice food and hospitality. Good warm shower block.
Then a short drive to walk up Mam Tor. Diesel heater - priceless!! First weekend away this year.
Depends how adventurous in your Travels you want to be? 20" and Lowering will certainly be a limiting factor.New wheels? 20"? Really nice. I still have the bland standard 17" alloys, can't decide if I should go up to larger wheels and lowering or higher with fatter tires for offroad.
