Load - through hatch
Rob65
Rob65
Birmingham
T7 California Coast
Just wondered if / how other members make use of the load-through hatch on the Ocean?
Also depends if you have the puncture repair kit in there (new models with low profile tyres) as the kit takes up more room, unfortunately.
I keep my daughter's wheelchair ramps (for negotiating steps) in there.
Her electric wheelchair, which folds up, lays on its side under the bed.
We use ours for skis, presume it is the same as the T5.
just taken the awning off .... fits through a treat, but not so easy to wind out
What’s the technique for getting the cover off? - tried a few times but worried about breaking the plastic cover.
If you pull it from the top it’s on a kind of semi hinge. Needs a strong pull. If in doubt tap it from the back with something long and it will come away on its own. That’s how I found out how to do it accidentally!!
Please excuse my noob question... What's a load through hatch?
It's the narrow gap under the seat between the under-bench drawer and the kitchen unit. Has a pull-off grey plastic cover flush with the drawer front. Can be used for stowing long thin items such as skis.
TPS......this link may help....
https://vwcaliforniaclub.com/threads/guide-fitting-the-small-under-bench-drawer.1768/#post-14011
Unfortunately the guide pics are no longer available. But if you are a VIP member you can download the Guide for doing this.
One word of warning, the draw code is not up to date so if you order get the to check the code and make sure its the correct colour, in my case moonrock grey.
Thanks, interesting..could i ask where you purchased the bits, please?
Wogga
Craig Morrison
johns6809
DanKavanagh
D
homerorchid
homerorchid
homerorchid
camper-x
