on my travels and the inlet lid has become loose. The thing is flapping as I drive along. Apart from taping it shut has anyone found an easy fix and also is changing the whole unit an easy job?
I started a new thread after trying all sorts of search terms. Happily Loz sorted my post out.For the third time
There have been three separate threads on this subject in the last half-day.
Edit: 4 threads.
Mine used to need a bit of force to click shut but I guess 3 weeks of Spanish sunshine have ruined it.Have you tried giving it a little push after closing?
sometimes it doesn't quite click into place, looks closed but a little push on the bottom edge does the job.
As so many of us are having the same issue perhaps VW should help us out. A class action perhaps.
Update: had no more problems with my Velcro pads fitted. Several days of travel.I am going to give this Velcro solution a try. When the flap closes male meets female and like us vaners never part again. View attachment 35589
Is this an exact fit for the cali as I've caught my flap with the foam brush while cleaning the van and it's crackedA replacement socket is easy to source and fit, but you will need a Torx screwdriver to remove the socket from the side of the van.
The cables behind it are just the same as changing a 13amp plug in your home. Can all be done from outside the van.
I was lazy and got my replacement from my VW dealer, but the bay has them too.
https://www.ebay.co.uk/p/240v-Carav...ains-Inlet-Black/17017005806?iid=151252615875
Don't be tempted to use another type as the fixing holes have to align with the holes in the body panel behind the plastic trim.
Alan
As far as I can see it is exactly the same item.Is this an exact fit for the cali as I've caught my flap with the foam brush while cleaning the van and it's cracked
Oh ok I thought you'd bought and fitted one yourselfAs far as I can see it is exactly the same item.
Alan
Yes I did, except I bought a replacement from my local VW dealer, a bit lazy really, as I was in there for something else at the time.Oh ok I thought you'd bought and fitted one yourself
I'm with you I have no problem fitting it myself but concerned about the thing actually fitting the caliYes I did, except I bought a replacement from my local VW dealer, a bit lazy really, as I was in there for something else at the time.
I did fit it myself though which is very easy to do.
Alan
Hello.Black Velcro has solved the problem.
Now vehicles around me aren’t waving back at me any more.![]()
I can confirm that the item advertised is an exact match and took me 10 mins to fit well worth the £11 paid and a much cheaper option than buying from vwI'm with you I have no problem fitting it myself but concerned about the thing actually fitting the cali
