Winding in awning issue?
  • Thread starter Californication
  • Start date
Californication
T5 SE 180
Hi,
Has anyone had an issue when winding in/out the awning? Mine makes a clicking sound and nothing happens most of the time, seems like a gear may be worn? Any ideas appreciated! Cheers.
Sounds like the plastic gearbox is worn
Thanks for the reply guys, I'll check out the website.
Be careful fitting new gearbox. I seem to remember the awning is under tension & wants to unravel when you remove old one.
That's why I am a little nervous if its a DIY job. More investigation required first.
I replaced my gearing on the awning quick and easy job.
Mine is the Thule Omnistor 5102.
The awning must be opened fully so that there´s no tension on the
spindle.
Remove the plastic cap, you will need a stubby pozi drive.
The screws are on the inside of the cap.
Once the cap is removed you will see the 3 pozi screws that hold the gearing
in place, it´s just a straight swap.
