T6Beach
- Messages
- 196
Just come home and the wife says our high level break light is missing, either it has fallen out or someone has stolen it
Has anyone lost a 2nd one?
It seems, but I could be wrong, that it is the factory fitted lights that drop out.
a good way to solve this is to use clear silicone sealant clean and dry all around the area apply a generous bead and Bobs your uncle and rip off VW HAVE NOT MADE A BEAN OUT OF YOUStill waiting for the part to arrive for our new T6 Ocean, on back order!
Currently held in with electrical tape!
I cannot believe V.W. have not applied the industry standard F.M.E.A. (failure modes effect analysis) on this component and they will not sell the faulty part I.E. the plastic cover they try to sell you the whole unit ++amazon+amazon+amazon+amazon+amazon+amazon £35.00ish perhaps they are to busy Fiddling something else we do not know about YetWe have lost 2 - both replaced under warranty.
One time we did find the fallen off unit, and it was not broken. However it was impossible to get it to click back into place - I assume you have to press from both sides to make it click together, and that will need trim taking off on the inside???
Lucky the LEDs that are exposed when the lens fall off are red.
T
Could be due to temperature change and humidity. Could try using a hairdryer on the light until just warm and see if the condensation disappears.or lessens when it has cooled. If so repeat until clear. But heat only until warm.My indicator lights on the side have a few condensation blobs in them,,,, from when I got it a few months back....should I worry?
I keep meaning to take them off and dry them
Has anyone been able to get a refund from VW? I paid the £35.88 for a replacement in Feb. 2014 when my Dec. 2013 Cali went in for its first service believing it had been stolen.It's fallen out, T5 & T6 problem I'm afraid, very annoying but covered under warranty. Cover the hole temporarily to prevent water ingress.
