jts46
Didn't have a problem when in the RAF in Middle East or Far East
Mindful of “the troubles” in N.I. I still check under the van before getting in!
Is that running on 12v ? It looks big, can youDone a quick job just to show you. It can be a lot neater! The lead is connected under the front seat and attaches by an Anderson plug and socketView attachment 47905View attachment 47905View attachment 47906
So stop start system could wreck a turbo thenLetting the engine running idle for minutes won't really help in my opinion. When driving, you have more airflow, and the engine will cool better when driving than idle. When you stop, the heath from the tarmac will be much hotter to 'cool' down the engine. The only reason to let your engine run for a couple of seconds after stopping, is for the turbo to spin down, and let the oil run through it. If you stop your engine while the turbo is still spun on, then the turbo will spin off without oil when shutting the engine off.
Once (In 2000 I think) we returned from the south of France in my parent's car without airco (VW Passat from 1993). It was the hottest day on July 21st. We drove with all the windows open and the sunroof open. We stopped to try to cool down and got back driving as soon as we got out of the car and felt the heath from the black tarmac. It was much less hot while driving than standing still.
practicalmotoring.com.au
In the past maybe but the advances made in engine design and modern lubrication etc: to enable Stop/Start technology to work efficiently have made such a practice redundant in normal driving.
Myth-busting: Does stop-start damage your engine? | Practical Motoring
Plenty of people will tell you what they like and don’t like about stop-start systems. But, does stop-start damage your engine?practicalmotoring.com.au
I presume you slow down before you stop? I did mention “ Normal “ driving. But even so, the engineering improvements made for Stop/Start regarding bearings and lubricants would still have a significant effect compared to what was used 10 years ago.Sorry disagree. That refers to stop start systems which I guess only on average stop the engine for short periods before pumping oil round again. Im talking about where the engine has worked hard, high speed, hills etc and is then stopped. If I can do anything to help prolong my vehicles life then I will.
If you're getting rid when out of warranty then fine let the next user have the problems.
It’ll fit with the bed out or it could go on the passenger seat.Is that running on 12v ? It looks big, can you
make the downstairs bed with it in place and does
it work well.
I’ve used this one and the previous one in the Sahara where the ambient temperature gets hot in the day and chilly at night and haven’t experienced any problems.Sorry disagree. That refers to stop start systems which I guess only on average stop the engine for short periods before pumping oil round again. Im talking about where the engine has worked hard, high speed, hills etc and is then stopped. If I can do anything to help prolong my vehicles life then I will.
An engine with stop/start will have parts adapted to the system. And the engine will only cut out when "everything is fine".So stop start system could wreck a turbo then
