MattBW
Here to help
I don't.Why do beach owners buy those expensive 907 bottles?
I showed in a different thread that bought well, the gas in those '£1' cannisters available in every supermarket are cheaper than 907s bought in the UK. So I'm puzzled too why folks would pick a 907 and a separate burner (and probably carry a spare 907 for if the first runs out) over a £12 cartridge stove that sits nice and flat, takes up 1/3 of the room, 1/5 of the weight. If you are running a double stove / cadac outside I understand, but we are talking about the single burner, fixed inside a Beach.Why do beach owners buy those expensive 907 bottles?
I was using my portable stove under the awning last week in Austria when flames appeared from the valve area of the LPG canister, exciting but so glad it wasn't in the van at the time. That these cheap canister's are relying on an equally cheap valve/seal to prevent such leaks makes me a little nervous now.We have three 907's on the go. One in each of our two vehicles both complete with the full picnic gear. The third is in the shed and runs our large gas Cadac BBQ. These cylinders are a legacy from our SE owning days.
I prefer using them over the small throw away canisters firstly because they last for ages but more importantly, I've never been happy about having a pierced LPG canister in my van, albeit held in place inside a stove. The cost is secondary.
Those canisters that @2into1 mentions are EN417 type and are screw fit with a valve not piercing. 56 cans on +amazon+amazon+amazon+amazon+amazon+amazon works out at £4.60 a kilo compared with Campingaz at over £13 a kiloWe have three 907's on the go. One in each of our two vehicles both complete with the full picnic gear. The third is in the shed and runs our large gas Cadac BBQ. These cylinders are a legacy from our SE owning days.
For clarity, I'm referring to these cannistersThose canisters that @2into1 mentions are EN417 type and are screw fit with a valve not piercing. 56 cans on +amazon+amazon+amazon+amazon+amazon+amazon works out at £4.60 a kilo compared with Campingaz at over £13 a kilo
I see. I thought we were talking about the disposable C206 canisters. I'll get my coat.Those canisters that @2into1 mentions are EN417 type and are screw fit with a valve not piercing. 56 cans on +amazon+amazon+amazon+amazon+amazon+amazon works out at £4.60 a kilo compared with Campingaz at over £13 a kilo
I've actually got one of those stoves somewhere. Whilst it would be ideal for just the two of us, we have a large family incl 8 grand children. Hence the seven seat Beach. Accordingly, we often take our Cadac Carri Chef cooker with us. The 907 is ideal to fuel that as well.For clarity, I'm referring to these cannisters
To put in this £12 stove
The cannisters at Black's where I pinched the photo from are £2 each but unbranded ones can usually be found for £1 each at supermarkets / petrol stations. Although I think they are cost effective, it's their wide availability, light weight, and stable cooker design that keeps me banging on about them. Also, if you take three with you and have used two, you know exact where you are, which is very difficult with a 907 unless you are carrying scales as well.
The box is the same but different. The hinge is now on the long side against the side panel instead of being on the short (rearward facing) side.Is that the (end of the) 2 seater bench storage box also pictured? If so that is a different shape to the original one. Presumably because the new side trim is deeper. I would also hope the box is only 3 sided inside or your going to lose a lot of the storage space.
I do too, but our recent trip has made us really think about how we use our beach.
We mostly cook outside and used our Slidepod quite a lot over our 3 week trip but mostly for porridge, soup, tea etc. When the weather is bad however the beach can suddenly feel quite claustrophobic (I'm sure the ocean is no different). We use a Alpkit to make tea even outside but it can be used inside but cooking is a different matter we dont want to store extra cookers just in case, we are trying to travel as light as possible. This gets around all the issues we've had in bad weather plus I just love the design.
You can get some cracking deals on +amazon+amazon+amazon+amazon+amazon+amazon.Those Campingaz bottles are a devastating waste on the environment ....!!!
He's in denial.Might be time for you to step over into the dark side...![]()
Sounds like you in the market for an Ocean Matt...?
You would be amazed how much easier life becomes in the Ocean. Especially in bad weather, it makes life a lot easier...
Don't most Ocean dwellers usually end up on a Beach?I went the opposite way. I don’t think there is a perfect solution unless you’re made of money!
On definitely not In.Don't most Ocean dwellers usually end up on a Beach?
maybe after the weddingSounds like you in the market for an Ocean Matt...?
Just prior to our trip to France some builder had dumped a small amount rubbish in the road next to out house part of the rubbish was a very dirty 907 cylinder which I pick up.
Exchange it next day for a new one full of gas for £25.00 help by my sons contacts at GT towing. Happy days.
CI am sorely tempted once the new 6.1 beach is released to see if the the "kitchen" can be retrofitted. VW are renowned for trying change as little as possible to keep costs in check. I wouldn't be surprised if the part fitted straight in place of the current one, or maybe i am just being hopeful. As VW are doing several beach models with the same base vehicle it may be the same pattern.
I don't use the upper pockets and cup holders much so wouldn't miss them.
May be steep though, the plastic parts normally arent too bad but the cooker may be eye watering. Hoping they do release the beach in the UK so I can get a look at one and compare.
cooking in my Beach whilst reading This thread.I am sorely tempted once the new 6.1 beach is released to see if the the "kitchen" can be retrofitted. VW are renowned for trying change as little as possible to keep costs in check. I wouldn't be surprised if the part fitted straight in place of the current one, or maybe i am just being hopeful. As VW are doing several beach models with the same base vehicle it may be the same pattern.
