Birty
Not leaking yet but think I should be prepared! Whats the best tool for the small drain holes under sliding windows? Is a straight pipe or long and bendy? Should I be careful. easy to Pearce I presume!! T5.1 Cali..
. Need stronger specsno leaks yet that I’m aware of .. just maintenance really... do you know the cheaper grease.. vaseline maybe?Cleaning the rubber seal is also a good tip, there is some special
grease that vw flog but there is an alternative cheaper way.
Definitely not! The real stuff is Krytox and is priced like liquid gold! I use a silicon spray on a bit of cloth. Lots of lubricants actually perish rubber but I believe Silicon is safe.no leaks yet that I’m aware of .. just maintenance really... do you know the cheaper grease.. vaseline maybe?
I thought you would know what the real stuff is.Definitely not! The real stuff is Krytox and is priced like liquid gold! I use a silicon spray on a bit of cloth. Lots of lubricants actually perish rubber but I believe Silicon is safe.
Sounds great for maintenance! taI use this on the sliding window seals as well as the roof and door seals...
Gummi Pflege Rubber Care Stick 100ml Roll On * FREE Postage if you buy 2 https://www.amazon.co.uk/dp/B007TNOQDI/?tag=unique09f-21
There are drain holes at each end of the window guide slot. The slot/gap between glass and plastic is less obvious and only about 1mm x 10mm sook will try that but if its blocked then I would be surprised if a syringe would clear it?
Was wondering if a TePe dental stick would help? Still ain’t 100% sure i know which hole is a drain ♂. Need stronger specs
I doubt that it does much! Also I think its a "feature" that only appears on newer windows The picture attached is my replacement side window my original window on the side door just has the drain holes.only ever used autoglym but tbh getting fed up with certain aspects of it!Hi all,
slightly off topic but if anyone’s after good vehicle cleaning products, autobrite have an annual pre xmas sale on
Christmas Sale 2019 | Autobrite Direct Ltd
View our wide range of Christmas Sale 2019 products here at Autobrite Direct Ltdwww.autobritedirect.co.uk
Care to elaborate?only ever used autoglym but tbh getting fed up with certain aspects of it!
Just bought two today.. Thank youI use this on the sliding window seals as well as the roof and door seals...
Just cleaned mine today with that, used a small paintbrush to get to the rear part of the seal then wiped off excess with a tissue.Just bought two today.. Thank you
Tomorrows job if it ever stops raining!Just cleaned mine today with that, used a small paintbrush to get to the rear part of the seal then wiped off excess with a tissue.
There are a lot of those on Ebay with various different end, which do you recommend?Trombone cleaner, EBay. Used to use one to clean the roof drain holes on our Porsche soft top
Trombone cleaners are too big for the sliding windows drain as there is only about 1mm gap, use a water syringe.There are a lot of those on Ebay with various different end, which do you recommend?
