LockRack
CannonDale
CannonDale
Oban, West Coast Scotland.
T6 Beach 150
Anyone looking for a secure carrier for their SUP or kayak have a look at Lockrack, no need for straps or rope and the arms lock the board to the rack. The one I have will hold two SUPs or a kayak.IMG_0235.JPG
Looks like a good design, as raises the bottom bottom board slightly so should prevent the any slack in the boardbag from flapping on the roof (usually cured by turning the radio up!) Does it slide into the t-tracks on the top of the roofbars, and how do you tension it?
Yes it does slide into the tracks and to tension you just push the black bar inwards to secure the board, there is a key to release the arm and pull it out to remove the board.
I was just looking at the lock rack thinking 'what a good idea' when the OH points points out that an iSUP can just be deflated and voila! You can slide it out of the lock - or is there something I can't see?
Correct, the lock works best with surfboards / hard SUPs. It’s easy to just deflate ISUP and carry / store it in the van.
With my inflatable SUP I pass a cable through the webbing carry handle at the back of the board and either lock to the towbar bike rack or roof rack.
Not perfect but someone would need to cut the webbing if they want the board. Alternatively can do the same but using one of the double plates that fit in the fin box ta her than through the webbing loop
Anyone looking for a secure carrier for their SUP or kayak have a look at Lockrack, no need for straps or rope and the arms lock the board to the rack. The one I have will hold two SUPs or a kayak.View attachment 47732
Are the lockracks still going well? I'm thinking of getting some for my cali but worried about the extra weight when lifting the poptop (have a roofbox too)
Yes, works well but think the Ocean is limited re weight it can lift when opening the roof. I have a Beach and take the SUP off when raising the roof
@CannonDale thanks for the post. Looking into a Lockrack now (newer Extendable Set) to cut down on inflate/deflate time when taking family for a paddle. Looks like yours is an iSUP. Any issues transporting two iSUPs at 60-70mph? Not so much worried about security (theft via deflating) and plan to use a fin box lock.
More interested in feedback safety-wise as their .eu site (https://lockrack.eu/product/) doesn't recommend "to use the Double SUP Set for Inflatable SUPs," but that "you can use the Single SUP Set with an Inflatable SUP but only for short distance and only if fully inflated"
Martin
5K
Californiaman
Californiaman
N
6K
danny13
D
5K
Silverfox
L
mattsurfsgood
