Window ventilation
I
icic
UK
Just looking at ventilation. In the cab looking at wind deflectors or the Brandrup driver and passenger ventilation any thoughts on which is better ? Also how is clear plastic cover for the side window
The wind deflectors would be the retro ones
Wind deflectors are good if you are with the vehicle., Security.
The Brandrup./ Reimo window vents are good for ventilation when the vehicle is unattended on campsite.
I have both. Deflectors for overnight and vents for extended stays
I also have both and find very helpful driving (deflectors) and camping (both).
I was wondering if you could use both, so the brandrup ones will work with the wind deflectors do even when you put the clips into the window frames
Yes. I have Dubreflecta;s fitted and use the Ventilation grills at same time.
