john eagle
Eaglehead
Hi does anyone know if a 2015 Cal SE has a USB connection anywhere to play music from a memory stick and if so where is it located?
Depends on which Radio system you have and what Options were chosen.Hi does anyone know if a 2015 Cal SE has a USB connection anywhere to play music from a memory stick and if so where is it located?
As @WelshGas says , but if like me you have the RNS510 without the USB, you can use either the Aux input or put your music on an SD Card and use the SD slot on the head unit.Hi does anyone know if a 2015 Cal SE has a USB connection anywhere to play music from a memory stick and if so where is it located?
I have a 2015 Cal SE and there is no USB connection.Hi does anyone know if a 2015 Cal SE has a USB connection anywhere to play music from a memory stick and if so where is it located?
