P
peterbrown
- Messages
- 19
I have started to get and loud screech when reversing, bit like a grinding noise.
I presume it's not a 4Motion?Hi mine is a 7 gear DSG ! This only happens at low revs as mentioned ! All other driving , ie motorway , sepurb quiet motoring ???
OK, seems it is not the engine. When did this problem start? Any relationship to the DSG oil change? And was the oil change done by VW?Hi no its not 4motion
Done 49500 miles
Ok in neutral 2000 revs no noise
DSG oil changed September 19
Had all steering checked over last week
Power steering belt and tensioner changed last week
MOT all clear last month
Cam belt etc changed 2018
PB
Have they used the correct oil. That is very, very important. The correct oil is quite expensive and it has been reported elsewhere of problems when a cheaper oil, that is not exactly the same, is used.Hi and many thanks,
Come to think of it the problem has occurred since gearbox oil change and I noticed it soon after. Took it back as it sounded a bit like a vibration ! They check all underneath as thought perhaps something loose but couldn’t find anything. Not done by VW but by a VW specialist who I have used since 1997 ? But I’m glad you have asked that question as hadn’t given it a thought since but it has gradually got worse ??
Anymore thoughts are greatly appreciated.
PB
Good luck Peter,Many thanks for your input/advise Welshgas !
Sorry didn’t reply earlier but been working today ! Yes 72 and still working ( part time ) and as it looks ? To keep my Cali on the straight and narrow. Will book in with Chelmsford Van Centre tomorrow.
Thanks to all of you guys who have been kind enough to assist me with this ! Any other thought will be greatly appreciated.
PB
