Sorry, just seen your other thread. 2015 it isWhat year T5?
As above.Hi everyone, I’ve just purchased a Cali se t5. Just trying to get auxiliary heater to work I get it to blow cold air only, what am I doing wrong.
Any help would be appreciated thanks.
You must have that stored somewhere by now to copy and paste WG?!!As above.
What temperature level have you set?
What voltage is shown on the Control Panel?
How much fuel in the tank?
Check the Control Panel for any Diagnostic Codes.
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
Thanks will give it a go tomorrow , fingers crossedAs above.
Control Panel On
2015What year T5?
About 5min, about how long before heat?How long have you run it for? It does blow cold to start with.
I have.You must have that stored somewhere by now to copy and paste WG?!!
Can be longer than 5 mins.About 5min, about how long before heat?
Great advice everyone, big thanks got heat now battery low, had on charge over night started to heat after a few minutesCan be longer than 5 mins.
Do you hear a ticking noise inside or outside the vehicle?
If you do that is the fuel pump.
You should never run for just a few minutes in normal practice . The heater should be run for at least 30 minutes at a time. If there is a fault it will automatically shut down.
