If you want pretty much guaranteed tv coverage get an old style pronged aerial on an aluminium 3 piece pole and position it through a slot of the bike rack and secure with one of the bike prongs.Then feed the signal through a £20 vision plus VP amplifier and then into the back of your TV set. The set up can be run entirely in 12v mode if required, and I haven't failed to get a decent signal anywhere yet. Just need to work out the orientation - vertical or horizontal - of the aerial. This can normally be obtained by walking around the site and looking for a rig that has already worked it out for you.
We don't take the tv when we go on "the continent". No need because a lot of big whites have tv's on swivel mounts so that they can orient the tv externally for the benefit of all
