Same problem with joker, I was going to cut mine down but will be selling van very soon (new on coming).I have alway felt the internal table was to long, and a hassle to get around when trying to get to the passenger seat, so had it cut down and slightly reshaped. Still looks fairly original.
Hi hope all good with you. I may do something similar in the future will see how this one works out.Same problem with joker, I was going to cut mine down but will be selling van very soon (new on coming).
Sourced 500x300mm top and folding leg, just hooks on rail with two screw heads.
Have you got your 680 yet?
shop.vwcamper.de
They look great. Like the sound of the fill in bed. But should it be 460mm to fit between the bench seat and Captains chairsGot my table brackets 3D printed now ready to make my smaller table. Going 400x800 and an adjustable leg to allow it to also make a bed frame between the seats in due course.
Yes the gaps a bit wider as you say 460ish but at 400 the table tops cheaper and it can also be stored upright by the seat as per the link above. We’ve a 70mm deep mattress for the little one which doesn’t flex so squashed between the seats I don’t think it’ll fall into a 30mm gap either side. I’ll let you know if she ends up on the floor.They look great. Like the sound of the fill in bed. But should it be 460mm to fit between the bench seat and Captains chairs
Ok I’ve seen them on the German forum showing the same interested in seeing it completedYes the gaps a bit wider as you say 460ish but at 400 the table tops cheaper and it can also be stored upright by the seat as per the link above. We’ve a 70mm deep mattress for the little one which doesn’t flex so squashed between the seats I don’t think it’ll fall into a 30mm gap either side. I’ll let you know if she ends up on the floor.
My effort slightly longer and leaving room to swing your legs under.A new table for the 680. I'm very happy with the proportions. I can now easily get into the front cab and we have more room to move around.
Jesper is that the original table modified or complete new unit? Also can you tell me where you got your fitted carpet in living area please? My 680 is due for build next week so starting to plan some purchasesMy effort slightly longer and leaving room to swing your legs under.
thanks Jesper will have lookI kept the original for safety but not sure why. The table shown is OEM Grand Cali spec. Purchased another from our dealership. Then to a local joinery firm who cut it down to where I had specified and to shape then re edged it. They will need a banding machine to reapply the white edging.
The carpet is great very versatile and hard wearing, got it from our local supplier. Look up Alternative Flooring but ensure it’s the rubber backed version which is synthetic and rubber backed.
Forgot to add they cut a template.
good luck.
Just on the carpet you can order one from your dealer. It’s in the accessories catalogue.Jesper is that the original table modified or complete new unit? Also can you tell me where you got your fitted carpet in living area please? My 680 is due for build next week so starting to plan some purchases![]()
Evening yes you can, I have x2 carpets ie the one shown in my photo for summer and the one shown as premium carpet mat set for the winter. Helps stop thermal transfer in the winter. Well worth it.Just on the carpet you can order one from your dealer. It’s in the accessories catalogue.
Whole living area.so does the VW one cover whole living area too as assumed it was mainly cab area?
Well Done SvenHome work.
@Bendwg Great idea to get these brackets 3D printed. Would you want to share the design file? I'm also planning to make a slightly smaller table, and would like to keep the original one.Got my table brackets 3D printed now ready to make my smaller table. Going 400x800 and an adjustable leg to allow it to also make a bed frame between the seats in due course.
Hi the brackets look great. Can you help me - Where did you find the file for the printer ? ThanksGot my table brackets 3D printed now ready to make my smaller table. Going 400x800 and an adjustable leg to allow it to also make a bed frame between the seats in due course.
