Leisure batteries not talking to control panel
adydye
Hi,
I've read related threads but no wiser I'm afraid.
Engine off and not hooked up, the control switches off the fridge because it believes the leisure batteries are dead.
Both leisure batteries are fully charged.
I've checked the fuse on the rear battery and it looks fine.
Unfortunately, the plastic(?) double nut under the red cap disintegrated on reattachment. I reconnected the terminal anyway - is this a problem?
Is there another fuse i have to check re the control panel discrepancy?
Hi,
A little more information would help.
What voltage is shown on the Control Panel?
Have you reset the Control Panel and checked for any Diagnostic Codes?
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Do you have access to a multimeter? If so can you check the voltage on both batteries (check under the fuse on the rear battery, not above it). Both should be the same, and match the control panel number more or less. Anything different would raise an eyebrow - maybe the earth shunt under the fridge is broken or faulty as I believe that is used by the control panel to measure the leisure voltage.
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Is the procedure and error codes the same if you wish to access the control panel on 6.1
No, but then you didn't mention which vehicle you had.
Thanks for the replies.
The control panel runs quickly down to 0% after being hooked up or the engine running, so switching off the fridge.
I've checked both batteries and they are fully charged.
I will try the fault codes, thank you.
Is there a fuse chart for the T5 on here, please? Mine is in German.
Found the fuse info on here thanks
Just wondered if you managed to sort this as I’m having similar problems ?
Hi Ian,
Actually, no. I took it to an auto electrician on the day I was leaving for holiday and he narrowed it down to the split charge relay. We didn't have time to remove the seat to replace it though. Keep in touch and I'll let you know what happens.
Sounds like you've at least made some progress! Thanks adydye.
I had a similair problem, where the voltage reading on the control panel went down way to quickly and the batteries turned out to be just fine. First guess was that it was running on only 1 leisure battery. But eventually this turned out to be the earth shunt problem that @steve_b is referring to.
