Full list of options for T6.1 Ocean? (2021)
solutionz
NZ
T6.1 Ocean 204 4 motion
I'm looking for a comprehensive list of options / PR codes that may be currently available to order ex factory and/or ex dealer for the T6.1 Ocean.
Going through the latest brochures for the different countries (UK, Ireland, France, Germany, Australia, NZ) there are a number of codes only listed in one or two of them, or without codes, partial descriptions etc so requires cross-referencing between them.
For example 2021 VW Ireland T6.1 brochure lists:
[YEL] Equipment Package “Protection”
[YER] Underbody Cladding for Engine and Transmission, smooth aluminium
But then only the 2021 French brochure has the full descriptions (via Google translate) and lists them as options specifically for the T6.1 Ocean:
[YEL] "Protection" equipment package base plate protection for engine, gearbox, tank, rocker panel, differential, silencer. main
[YER] Underbody protection plate for engine and gearbox made of smooth aluminum sheet
This appears to be the Seikel kit however unclear if it's ex factory or dealer fit option.
This forum is the only place I see two mentions ({1}, {2}) from 2016 of [YEQ] Seikel Desert Suspension; again is/was this a factory or dealer option?
The 2020 French brochure lists two other suspension options; [1BJ] and [1BB] Uprated suspension/shock absorption in front and rear +20mm -are these similar to the above?
I've also seen claims that VB Air Suspension is/was a factory option? It at least seems to be a dealer option in some places however I haven't come across any codes for it.
I'm also looking for any docs specifically showing [IS2] Terminal strip (IS1) and multifunction control unit (IS6) or either of them (IS1 required for VB Air) specifically available for the T6.1 Ocean model as in addition to the base Transporter currently I've only been able to find it listed for;
UK T6 Cali Ocean
AU T6.1 Cali Beach (lists description without code)
DE T6.1 Multivan, Kombi, Grand Cali etc
It would be nice to know the difference between these:
[1S1] Tool kit and jack
[1S6] Heavy-duty tool kit and jack
And to have an updated listed of glass / tint options as the latest version I can find is on this forum for the T6 and is missing detail on [Z2C].
And of course to correct what is obviously the biggest spec'ing oversight for a camper it's be great to find a way to get these parts retrofit in NZ;
[199 398 500 A] and [199 398 500 B].
I've found a further breakdown of codes for underbody protection in a 2018 French T6 Transporter brochure;
[YEL] “Protection” equipment pack (engine, gearbox, rear differential, silencer and sill)
Warning: Oblige [S1X] Fitting for special equipment Only on 4MOTION and not available on TSI engines
(Appear to include YER, YEU & YEY)
[YER] Aluminum base protection for motor and gearbox.
Attention: Oblige [S1X] Fitting for special equipment
[YEU] Side skirts
[YEY] Underride protection for rear axle differential made of smooth aluminum sheet
Only on 4MOTION
[S1X] = Special installations by the Special Vehicles Business Unit (BUS) which implies these are factory options (apparently the case for all Y-codes).
I'm also interested to know if there are any rigid key (aka "surf key") options available for the T6.1 Ocean as was listed for the T6 Ocean such as below?
[8QG] 4 remote control folding keys and 1 rigid key
[8QL] 2 remote control folding keys and 1 rigid key
Is this what you're looking for? I came across it in a german forum (see link below). I don't know how comprehensive it actually is. This is a German to English google translation:
https://www.caliboard.de/topic/22514-codes-für-ausstattungen/
That list could be helpful as it looks like it contains a few extra codes however ideally it would be good to have a full list of the options / codes available, by T6.1 model (Beach, Coast, Ocean) and/or by region. As well as info on what options could/couldn't be retrofit.
You might have more luck on the T6 Forum that also covers the T6. 1.
Yes I've joined there however I'm looking for info more specifically related to the T6.1 California Ocean, as most options for the base T6.1 are a lot easier to find. Caliboard.de as mentioned above is probably better still if you're happy to translate German.
Hopefully someone will drop by with the useful info otherwise at least some of these esoteric codes will get picked up by Google now and maybe be of use to others.
Another query; this part is listed as an option for T6.1 (at least as a dealer addon) but wondering if there is a PR code for factory fit?:
[000 063 511 E] Universal Traffic Recorder (UTR) front and rear. (for: all countries, excl usa, canada, mexico.)
I tried and failed to do a similar task (comparing Swiss vs German vs UK). One issue is the configurators often have incomplete information, buggy logic, and even if you get through that, the actual dealers have again a different configurator which is the final check on what is and what is not allowed.
e.g. "235 tyres" on the Swiss site are NOT all-season, but "235 tyres" on both the German and UK sites ARE all-season
Therefore I'd say good luck in doing all your own research, but keep in mind that you might need the dealer to really verify what is possible to order or not.
Or is your plan to order direct from the VW factory?
I'm trying to order some parts to upgrade a T6.1 Ocean, and also spec a new T6.1 Ocean through NZ dealers.
VW NZ only list a fraction of the options available overseas however so far they've been able to add some additional things when I've provided them with the PR codes.
It's easiest if I can point to an official VW T6.1 Ocean brochure with the full description and PR code I'm after to prove it's available specifically for the Ocean; so the dealer can follow up with VW NZ, and in turn with the factory.
Would it help if I pasted an extract from my actual order? Bit more detail than the online configurator, with codes, but its in German (nothing google translate cannot fix).
If it helps I'll put that together.
That may be helpful if you have any of the options above factory fitted or have any unique codes.
e.g. It took me a while to find out what [4IA] was from my label which ended up being fairly uneventful "Emission standard, EU6DG as NEDC/ UN ECE83 EU6ZD".
Ok here goes.
This is a direct copy and translation of my actual order for my van from the dealership from last week. My order is in German, so I've just used google translate to get the English. There might be some strangely worded sentances or US-English spelling, so don't take it as 100%.
You have the category, the factory codes, a description, and the swiss franc price. Some of the "options" are quite funny e.g ZZX is just text to say that the standard features might be replaced by the optional extras, but will still be listed. That might even help you because its more than you can see on the configurator sites.
** MAIN VEHICLE **
  • Brand: Type VW Commercial Vehicles / California 6.1 Beach Edition Spirit
  • Color: Interior candy white (LB9A) / Art Velours Palladium black
  • Engine: PS / ccm 2000ccm 150PS / 110kW 4 cylinder TDI Common Rail EU6 SCR Diesel
  • Transmission: 7-speed automatic DSG front-wheel drive
** STANDARD FEATURES **
[1G8] Tire sealant and 12 volt compressor
[5K6] Transport protection measures normal roof
[7X2] Ultrasonic parking aid front and rear
[8T6] Cruise control system including speed limiter
[EJ1] Extension guarantee 2 + 1 100,000 km
[PKO] Comfort control panel incl. Climatronic, decorative. Brushed gray / titanium black-palladium and blackout blind front window
[QL5] Dark colored windows in the passenger compartment
[R27] We Connect Plus 3 years
[WVK] Special model California Edition Liberty
[WVU] Special model Beach Edition Spirit
[X] ESP, electronic stability program
[X] Leather multifunction steering wheel with controls for radio and telephone
[X] Central locking with radio remote control
[X] Heated rear window
[X] Airbag for driver and front passenger
[X] App-Connect
[X] Electric windows
[X] Electronic immobilizer
[X] ISOFIX child seat anchorages at the rear
[X] Diesel particulate filter
[X] Tire Mobility Set (tire sealant and 12 volt compressor)
[X] Tire pressure control display
[X] Engine start-stop system with braking energy recovery
[X] Bed extension with cushion at the back
[X] Side and head airbags for driver and front passenger
[X] 6 speakers
[X] Crosswind Assistant
[X] sliding door on the right
[X] Electromechanical power steering
[X] 2 swivel seats in the driver's cab
[X] 2 folding chairs in the tailgate trim
[X] Electrically adjustable and heated exterior mirrors
[X] Hill Start Assist
[X] awning rail black
[X] Multipurpose table in the sliding door panel
[X] All-round darkening of the sleeping area
[X] Deep Black mirror housings and body-colored door handles
[X] Slidable 2-seater bench / bench
[X] 12 volt socket
[X] Multi-collision brake
[X] DAB +
[X] LED main headlights with LED daytime running lights
[X] mini kitchen
[X] Interior lighting concept Camper including lighting in the pop-up roof and tailgate
[X] "Climatronic" air conditioning system with air vents at the front and rear
[X] 70 liter fuel tank
[X] Indoor lights and reading lights
[X] Manual pop-up roof
[X] Fog lights with cornering lights
[X] Double bed with spring plates on top
[X] Preparation for roof rack (C-rails)
[X] Camper approval
[X] Sliding window in the front left passenger compartment
[X] 1st additional battery 75 Ah
[Z0C] 4 aluminum rims "Aracaju" black, high-sheen 7 J x 17
[Z4A] Light & vision package
[Z6B] Beach Edition package
[ZEO] "Premium" multifunctional display with multicolored display and drowsiness detection
[ZIE] Radio navigation device "Discover Media" 6 loudspeakers, 8 "touchscreen, 2 USB interfaces (type C), streaming & Internet
[ZZX] NOTE: Listed standard equipment can be omitted due to selected additional equipment!
** OPTIONAL EXTRAS **
Exterior color
[B4A1] Candy white (LB9A) 275.00
Interior
[GV] ArtVelours Palladium-Black 0.00
Outside
[1D2] Hitch, detachable and lockable (including trailer stabilization) 1'040.00
[3RJ] Servo closing tailgate 175.00
[4FJ] Sliding window with fly screen at the front and fixed window at the rear in the loading / passenger area on the left 90.00
[4JJ] Sliding window with fly screen at the front and fixed window at the rear in the loading / passenger area on the right 370.00
[5R7] Servo locking sliding door right 175.00
[7B5] 230 volt charging connection with battery charging function and 230V internal socket 835.00
[8W4] heated windscreen washer nozzles at the front and washer water level indicator 80.00
[JI3] Electro-hydraulic pop-up roof and mosquito net in the bellows at the front with front opening Basalt Gray 2,390.00
[NF1] awning, 2.5 meters black 685.00
[Z2A] Insulating glass with improved exterior noise insulation and darkened panes in the passenger compartment, sliding window normal glass darkened 460.00
Chassis / wheels
[1G2] Spare wheel with steel rim 110.00
[2E4] 17 "chassis with 17" brake system 180.00
Inside
[0F5] Fuel tank with 80 l tank volume 85.00
[9M4] Air auxiliary heating and water auxiliary heating, programmable, with radio remote control 2,790.00
[KA1] Reversing camera "Rear View" 330.00
[PKP] Comfort switch panel incl. Climatronic, decoration. Brushed gray / titanium black and blackout blind front window 0.00
[QR9] Traffic sign recognition 315.00
[ZEQ] Digital cockpit and drowsiness detection 530.00
[EM1] Drowsiness detection 0.00
Seats
[N3R] Velor seat covers 1'415.00
[ZNO] Electric seat adjustment for driver's seat with memory function (not rotatable) 1'545.00
[ZV3] 3-seater bench in the passenger area including multiflex board and 3 drawers 0.00
[3U1] Comfort sleeping pad for bench 420.00
Security
[7X5] Parking assistant 235.00
[8G1] "Light Assist" (high beam control) 180.00
[PAC] Automatic distance control ACC up to 210 km / h including speed control system 960.00
[8T7] Automatic distance control ACC 0.00
[6K4] "Front Assist" environment monitoring system with City emergency braking function for automatic distance control up to 210 km / h 0.00
[Z0X] "Side Assist" lane change assistant incl. "Lane Assist" lane departure warning system 830.00
[X] Lane Assist "Lane Assist" and "Side Assist" lane change assistant 0.00
[X] Parking assistant 0.00
[X] Electrically adjustable, foldable and heated exterior mirrors 0.00
Miscellaneous
[1S1] Tool kit and jack 0.00
Equipment Switzerland
[# U8] Without guarantee of follow-up 0.00
[# Y7] Without VanCare 0.00
** END **
Ok here goes.
** MAIN VEHICLE **
[X] App-Connect
[X] 6 speakers
[X] 12 volt socket
[X] DAB +
[X] mini kitchen
[X] Camper approval
Exterior color
Interior
Outside
Chassis / wheels
Inside
Seats
Security
Miscellaneous
** END **
@solutionz was this any help?
