blondebier
Edit: I try not to stop the engine when it’s is part way thorough a regen
Surely the "software fix" should let the regen continue when the engine is turned off. (Like it does on the T6)
Why does it stop when the engine is turned off?
Not ideal but you can change your engine oil with much greater frequency to help reduce the “Dilution“ effect.Just depressed myself reading a couple of threads on the T6 forum about high oil levels and fuel contamination AND VW’s total inability to resolve the issue for all affected owners.
What really concerns me is the potential for engine damage if the oil is getting diluted with diesel fuel. I’ve got a 5-year warranty but intend keeping the van much longer, so it matters to me.
Even though i’ve not yet had this issue I am shocked to read that so many other owners have it - some with new low mileage vans.
I’m awaiting a response from a Van Centre but unless they advise of a forthcoming ‘fix’, I intend to try and get a statement in writing from VW with appropriate assurances.
If I understand it correctly, when a regen’ starts diesel is introduced into the cylinder on the exhaust stroke so it’s obviously unburnt diesel. The intention is that the unburnt disel then arrives in the DPF and then ignites and raises the temperature to burn off the particulates. If the engine stops and even if the regeneration continues then the unburnt diesel that is sitting in the cylinder(s) can seep into the oil sump.Surely the "software fix" should let the regen continue when the engine is turned off. (Like it does on the T6)
Not aware of any difference between T6 and T6.1 in this regard, both regen same way; issue has been reported in both.If I understand it correctly, when a regen’ starts diesel is introduced into the cylinder on the exhaust stroke so it’s obviously unburnt diesel. The intention is that the unburnt disel then arrives in the DPF and then ignites and raises the temperature to burn off the particulates. If the engine stops and even if the regeneration continues then the unburnt diesel that is sitting in the cylinder(s) can seep into the oil sump.
Is that a correct understanding?
That would concur with the Oil being correctly filled, allowing for expansion of the oil from below the max line when the engine is cold (on the dip stick) to the Max Line during normal use.From stone cold measurement on the dipstick (about 2/3 full on the hatched section), then drove it for 1hr40, oil at 105c when turning off. Left it for 5 mins then dipped oil - was right to the top of the hatched section on the dipstick
I was under the impression that from the T6 onwards they have been fitted with a sensor to sense when oil quality drops below a certain threshold.That makes interesting reading
“Cut the oil service schedule in half”
What is the duty cycle of your van OP?
Are you using it for short journeys and therefore causing many regens?
I like the “manufacturers adding an extra notch on the dip stick. Genius.
I think you just answered your own question!So much writing when is little extra or little less oil, - make more or take away too much - how is peoples make such complicated problem?
I having extra water my fridge but if I say such situation, maybe I am give chart picture and graph explain why is such water my fridge!
The Hatched area on the dipstick represent approximately 1 litre of oil, so if my calculations above are correct, your engine oil would show at the maximum mark on the dipstick when the engine is upto operating temp. (I.e full engine oil volume increases by about 400ml at normal operating temp)![]()
I literally just picked my van up from an oil service.Yep - which would suggest that the oil level should be filled to approx half way on the dipstick when engine is cold - and I suspect my van was PDI'd and the oil level filled to the top of the hatched section when cold - seemingly incorrectly.
Plenty more to come on this I think...
Interesting Comment.Well - that is certainly what the master tech I've been talking to is saying he is seeing. He has to PDI new vehicles and they are coming from the factory with the oil half way on the dipstick (and it appears it should be left like this), whereas some techs have been topping it off because they think it was a factory error - where it is not.
Will be interesting to see what level yours has - although it might be different for a T6 than a RDE1 or RDE2 T6.1 possibly...
Mine had an oil change service last week so will check the level in the morning too.I literally just picked my van up from an oil service.
I will look tomorrow and report back accordingly.
surely the factory fill the engine oil, to the “factory” measure,
the PDI is presumably a visual check by the dealer, to ensure the oil level is showing on the dip stick ?
from what you suggest, I wonder if some dealers are then topping up the engine oil above the factory measure?
So literally just a shorter dipstick!! That’s not solving the problem is it, that’s just changing the way you measure it ffsCan't answer that as I've not spoken to any other VW techs about this and what is/was common practice.
The understanding I have (now) is that the software fix is more about allowing a greater tolerance for high oil level above the top of the hatched area on the dipstick when the oil is warm. I have no idea how this works (ie if it changes what level it looks for depending on oil temp too) but that is my understanding of the change. And.. apparently this is only available for RDE1 engines not RDE2 yet although they are working on it.
Well, I can see some logic in it as if it genuinely is oil expansion when hot that is triggering the 'reduce oil level' warning and this is too sensitive at the moment, then the software fix will help with that - as would a physically shorter dipstick too of course as long as the oil fill level was actually adjusted to fit it too.So literally just a shorter dipstick!! That’s not solving the problem is it, that’s just changing the way you measure it ffs
You would need a longer dipstick rather than shorter so that less oil is put in.Well, I can see some logic in it as if it genuinely is oil expansion when hot that is triggering the 'reduce oil level' warning and this is too sensitive at the moment, then the software fix will help with that - as would a physically shorter dipstick too of course as long as the oil fill level was actually adjusted to fit it too.
I did come across some articles online about a Golf model (I think) where VAG did issue a new dipstick for it...
