We have 2012 Beach....
T.5.1 - We added USB for direct connection to a new head unit, you can get the usb dash plugs on ebay (just message the seller and they will be able to supply with bare wire to USB - instead of - USB to USB), then piggy back off your existing 12v dash wiring; See below link, they also do a double:
Genuine VW Transporter T5.1 Dash Blank modified to have a single flush fitting USB Port . This is for a T5.1 (2009-2015) facelift (retangular dash blank). These allow you to have all connection wires to be hidden behind the dash and provide a really neat solution for.
www.ebay.co.uk
Its also easy to add a hidden one in the glovebox if required. There is a plastic blank in the top right corner of the glovebox that is easy to prise out, drill a small hole in the blank to route the cable, and then replace, or, screw a surface mount onto the inside of the glovebox. Glovebox keeps your phones out of sight if you should forget to remove them when parked up:
CAMPER VAN 12V/24V USB SOCKET. Campervan Caravan Boat. Camper Van 12v Fuse Box 6 Way Blade Fuse Box Marine Caravan Self Build 12v 24v. For 12v / 24v. High quality usb socket. 1x twin usb. 12V CAMPERVAN PREMIUM RANGE.
www.ebay.co.uk
