B6POB
Heres a little swap for anyone who may be interested. I decided I didn't want adapters in my euro sockets as I spend my time in GB and if I go abroad I will run an adapter for the trip.
CBE 240v 3 pin socket is a straight swap, just pop the surround off, remove the screws and wires then reverse the process.
The 12v socket is a genuine vw unit that uses the same T connector plug, I found this in the boot space of a golf in a breakers. Fitting is slightly more involved, I removed the panel and had to open up the hole in the panel and rear metal strengthening plate, I used the connector front cover as a template and simply enlarged the hole with a file. Reassemble and that's the job complete
All in a simple mod anyone can do in an hour.
Sent from my SM-G960F using Tapatalk
