Is that the 16 inch Clayton wheel. Do you have the full spec for the tyre I.e load and speed rating ? I get very confused when looking at these whether the suv will be ok or a higher load rating is needed.Took my time to decide, but eventually fitted Crossclimate 2’s and an Isotop in preparation for travelling to Porto via Bordeaux and Sant Sebastian this Nov.
Any other recommendations?
View attachment 98899View attachment 98900
Add a few extras and the costs soon mount up !!2 popular choices there across members on this forum..
You know I really did not want to splash the cash for an Isotop and it still frightens me to look at the cost but I wouldn't have upstairs any other way.
And the cross climates are a solid choice, I think my Cali came with Turunza's and when I needed to change them I got the cross climates which apparently more hard wearing, just as quiet and of course the extra season confidence.
I haven't been out of the country yet during winter and have found a good sleeping bag and the heater to be more than adequate in staying warm upstairs in around +3 degrees over night.I wouldn't have upstairs any other way.
No they are standard fit 17J Aracaju alloys. With 235/55 r17 Y (103) on. I probably should have gone for the SUV’s but both choices seem fine for my use. Y is well over spec’d but 103 is the right load rating and 235/55 are practically the same rolling circumference as the Bridgestone 215/60’s that came off. On offer at black circles too as it was the middle of the summer when I bought themIs that the 16 inch Clayton wheel. Do you have the full spec for the tyre I.e load and speed rating ? I get very confused when looking at these whether the suv will be ok or a higher load rating is needed.
Too early to tell but happy so far. It’s a very tight fit and with the 6.1 you have to remove the front panel to close the roof. Hoping it will be cooler in the summer too.I haven't been out of the country yet during winter and have found a good sleeping bag and the heater to be more than adequate in staying warm upstairs in around +3 degrees over night.
2 reasons why I haven't taken the plunge on an isotop yet are the price and the lack of space in the roof area with the storage net only just able to fit with the roof down and the shutter closed. I presume I would have to ditch that?
Why do you rate your isotop so highly?
I will agree. Though, with such a large bed, would like to stretch out a bit more and did not want to change my excellent mummy sleeping bag.I haven't been out of the country yet during winter and have found a good sleeping bag and the heater to be more than adequate in staying warm upstairs in around +3 degrees over night.
For me, with a T6, there is sufficient space to in the roof. I am sure that it should be able to accommodate the storage net, if you take it off and lay it laterally, rather than closing the roof with the net in place - a hassle I know, but it is possible.2 reasons why I haven't taken the plunge on an isotop yet are the price and the lack of space in the roof area with the storage net only just able to fit with the roof down and the shutter closed. I presume I would have to ditch that?
I think I replied to a post of yours before (not 100% sure) but you can close the shutter with an isotop and the storage net in placeI haven't been out of the country yet during winter and have found a good sleeping bag and the heater to be more than adequate in staying warm upstairs in around +3 degrees over night.
End Sept is the recommended time, but with the change in general climate pattern, not sure if there is a change in schedule and specification on the Winter air ...Elsewhere on the forum you will find that you need to consider changing to winter air in those Crossclimates.
Nooooooooooo not again.Elsewhere on the forum you will find that you need to consider changing to winter air in those Crossclimates.
Winter Air in the North ++, but in the South of France/Spain ??End Sept is the recommended time, but with the change in general climate pattern, not sure if there is a change in schedule and specification on the Winter air ...
... grab coat and off to search for the Winter Air thread ...
Now that is the first time I have heard that. I think we need to definitely pop this into the winter air thread - just to preserve our suggestions for future generations!Just pop your tyre pump in the freezer for a couple of hours before topping up your tyres ..
winter air
What is the best winter air to put in my tyres now its getting colder?vwcaliforniaclub.com
Done.Now that is the first time I have heard that. I think we need to definitely pop this into the winter air thread - just to preserve our suggestions for future generations!
@ardm17 , are you able to update the above thread with your suggestion please.
Plenty.Cleaned out the front wheel arch liners:
How many years is that? (to help me plan my maintenance clean as wellCleaned out the front wheel arch liners:
That is since last year,How many years is that? (to help me plan my maintenance clean as well![]()
Time for a user manual then?That is since last year,
remember that as well as the wheel arch liner being subject to the crud thrown up off the front wheel, it is also the drain point from the scuttle which the roof drains into.
the scuttle collects anything that falls through the slots in the scuttle cover and if your lucky get washed into the wheel arch liner.
i also cleaned out the scuttle, removed the panel, there was at least three handfuls of rotting debris in each side recess, which was surprisingly wet despite no rain.
Updated my postTime for a user manual then?![]()
