Yes two itemsAssuming you’re askign for two things, not an all in one…
We have the Outwell Whistling kettle - we had a cheap one at first and I threw it away, absolute rubbish. The Outwell is great.
For coffee I have the AeroPress, but if it’s the bestest stovetop you want it has to be Bialetti, also on Amazon.
Cook sets - buy online here from Outwell
www.outwell.com
We have a ridge monkey kettle and an aero press. The Low profile square kettle would be great except the square lid sometimes falls into the kettle body.Need to know the bestest kettle and stovetop coffee maker please.
Not feeling the Chinese Amazon tat tbh
agreed. make sure it is indeed a Bialetti and not a (Chinese) lookalike. You want proper seals and proper valves!Absolutely agree about the Bialetti. I use a cheap camping kettle which boils quickly and just fits into the sink for travelling.View attachment 99007
We have the Outwell collapsing as well (for some reason or another we ended up with 4 kettles in the pre-delivery excitement) and the size is great but the lack of a whistle meant we just leave it at home now.Outwell collapsible kettle, aeropress & decent ground coffee.
(…Instant coffee is the devils work)
We have the Outwell and the size is great but the lack of a whistle meant we just leave it at home now.
It’s all go !earlier it was the coffee porn thread ... now it is a kettle and coffee porn thread combined ... OMG!![]()
Do they come round and make it for you at 360€Sea to summit collapsible kittle is great. Takes up no space and doubles up as a saucepan. If you want a decent coffee maker then check out the 9barista. Coffee made by anything else is pig swill.
I agree, it’s a lovely machine but the quality of the coffee rather depends on the beans and water that you use. Do have any recommendations?If you want a decent coffee maker then check out the 9barista. Coffee made by anything else is pig swill.
Living in a town with one of the world barista champions leaves me a little spoilt for choice. However, the beans front I’ve spent most time on recently are from http://thecolombiancompany.com/ they are decent.I agree, it’s a lovely machine but the quality of the coffee rather depends on the beans and water that you use. Do have any recommendations?
Agree it’s not cheap but it’s a work of art and should last a lifetimeDo they come round and make it for you at 360€![]()
Why does it need an induction plate? Is it made of aluminium?Agree it’s not cheap but it’s a work of art and should last a lifetime![]()
Sometimes it just be that way. A real bargain requires a real investment.Agree it’s not cheap but it’s a work of art and should last a lifetime![]()
Its quite a small base and the plate helps to spread the heat on gas / make it more stable on the burner top. For small camping burners it’s less of an issue.Why does it need an induction plate? Is it made of aluminium?
The induction one is for use on induction hobs as it’s alleyIts quite a small base and the plate helps to spread the heat on gas / make it more stable on the burner top. For small camping burners it’s less of an issue.
If only they'd managed to find a way to get rid of the hideous cheap plastic "chimney" on the back..."A monstrous carbuncle etc etc".Agree it’s not cheap but it’s a work of art and should last a lifetime![]()
