Nice kettle van colour coordination
It was a little tonge in cheek but if you are after a small gas powered espresso maker the alternatives are somewhat limited. Appreciate some prefer French press etc.If only they'd managed to find a way to get rid of the hideous cheap plastic "chimney" on the back..."A monstrous carbuncle etc etc".
And to say "coffee made by anything else is pig swill" is ridiculous (or irony)
Cafetiere works well at home, but in our van we need things that bounce when dropped.Outwell collapsible and a regular glass plunger type cafetiere. Why overcomplicate matters?
I do have a glass plunger type, and have to grind me beans, then add a few big spoons of ground coffee. But usually find I make it too strong or too week.Outwell collapsible and a regular glass plunger type cafetiere. Why overcomplicate matters?
Pourable spout ?Pardon my ignorance here but what’s the point of a stovetop kettle compared to a sauce pan with lid (which I imagine we all already carry in our van)?
Outwell collapsible kettle, aeropress & decent ground coffee.
(…Instant coffee is the devils work)
The taste of the coffeewhat’s
The whistle can be handy.Pardon my ignorance here but what’s the point of a stovetop kettle compared to a sauce pan with lid (which I imagine we all already carry in our van)?
That kettle looks the dogs. Love it !I use a Le Creuset kettle and Moka pot. The kettle stays on the silicone mat and does not move no matter how bad my driving gets! Used to use my Aeropress but had a couple of hot coffee related accidents with so the Moka pot stays in the van permanently.
Le Creuset are not exactly weight saving items - This could push certain forumites (You know who you are!!) over their Cali's payload limitThat kettle looks the dogs. Love it !
Aha, very true, I’ll stick with my £12 folding handle kettle !Le Creuset are not exactly weight saving items - This could push certain forumites (You know who you are!!) over their Cali's payload limit![]()
Should be a max fill line inside the bottom water chamber. The amount of grounds you put in doesn’t impact the coffee fill at the top. Rough grind normally best for flavour transfer and perculation. On a 4 cup Bialetti I use between 1 and 2 tablespoons. Half for a 2-cup.The bialetti brikka is an absolute nightmare to use. Tried using it on my roar stove in the kitchen and it just fills the top pot full of hot coffee, then starts spitting and overflowed like mad.
I’d only put in 120ml of water and half the coffee.
The instructions don’t tell you how much coffee to put in. I’m using pret espresso #5 and doing a rough grind.
What a ball ache.
Not a fan.
Need to research a different coffee maker.
With no stress n mess.
Yep 120 ml is for 2 cupsShould be a max fill line inside the bottom water chamber. The amount of grounds you put in doesn’t impact the coffee fill at the top. Rough grind normally best for flavour transfer and perculation. On a 4 cup Bialetti I use between 1 and 2 tablespoons. Half for a 2-cup.
A while ago I watched a YouTube video on Bialetti with the following advice, which has improved my coffee making.Yep 120 ml is for 2 cups
Maybe I’m putting too much coffee in
