Fordiesdocamping
There is a setting for auto wiper in the menu, the stalk doesn't seem to have an auto mode on it. Do i take it that the auto is only for the rear window wiper when reversing? And the auto front wipers are an extra?
Welcome, and you are Correct.There is a setting for auto wiper in the menu, the stalk doesn't seem to have an auto mode on it. Do i take it that the auto is only for the rear window wiper when reversing? And the auto front wipers are an extra?
Great thanks thats that sorted. now all i ned to do is figure out how you can play music from an SD card when there are no slots available!Welcome, and you are Correct.
Auto wipers are an option and there would be a windscreen sensor near the mirror.
SD card slot in my standard 6.1 Coast head unit, which I use all the time. Which vehicle do you have?Great thanks thats that sorted. now all i ned to do is figure out how you can play music from an SD card when there are no slots available!
Same here.I bought one of these ...
https://www.+amazon+amazon+amazon+amazon+amazon+amazon.co.uk/dp/B07YYJRXQR/?tag=unique09f-21
I have a Discover Media, works with no issues, continues playing from where it left off. I don't know if your system allows software updates over USB but there needs to be absolutely nothing on the stick apart from the music, if it finds something that it thinks is bootable then it will do exactly what you are describing.Same here.
How is your experience with usb key?
When I plug it in, it works great, but after I turn the engine off and on again, the radio starts to reboot itself over and over again, until I remove the usb key.. I can reconnect it immediately and it will again work fine, until I turn the engine off again.
I have a standard radio, fwiw.
