Sp0_0k
- Messages
- 1,247
- Vehicle
- T6 Beach 4Motion
Was most probably caused by stuck water drain hole on a window. Had to use some pressure to clean it.I wondered if you found a solution to this? We have a 2017 T6 Beach and when it rains the cup holders fill with water. If you have found a way to fix this issue, please let me know! Thank you
Me too - to clear the 2 x drainage slits in the side window channel we ended up joining a drinking straw, plastic tube and syringe - easy...Thanks for letting me know. Sorry about the tailgate though. How did you manage to clean out the stuck water drain hole? I' can't figure out what I need to do
