Californication69
Bill
I’ve been experiencing strange issues with my Lesuire batterys, Solar, starter motor battery and fridge.
Going to document my investigation as I go.
Found so much information from this forum, so thanks to all.
I’ve removed all USB cables from front USB.
No 12v plugs occupied.
Solar is removed from California and Lesuire and starter.
First thing I checked.
Rear Lesuire battery cube fuse.
Surprise, 100A cube.
Not blown as checked +&- terminals and checked top connector + and battery earth strap.
Then checked Pass batt.
Then checked Starter motor.
Found the following voltages.
30th June 2023 13:00
1 hour motorway journey with max charge on.
CP showing 14.4v and 32A
30th June 2023. 21:24.
CP 12.5v -1amp (minus 1A)
Put fridge on #3
Says 12.5v -4 amps.
Should run fridge for 5 days on fridge setting #3
Start batt 12.5v
Pass Batt 12.5v
Rear Batt 12.5v
Rear Batt 12.41v with fridge on.
Engine (running) all 3x Batts at 14.45v
(So lost 0.2v in 8 hours)
1st July 2023. 10:30
(Doors & bonnet opened at 09:45 and all Lesuire light cabin switch off, then left everything open for 20minutes)
CP 12.3v -1A
Front batt 12.3v
Pass Batt 12.4v
Rear Batt 12.4v
Rear Batt 12.31v with fridge on.
Engine running all Batts at 14.45v
2nd July 2023. 10:00
CP 12.2v -1amp
FB 12.18v
PB 12.2v
RB 12.2v
LB 12.1v with fridge on.
Engine on, all Batts at 14.45. Eng Off.
10:30 to 12:00
Turned night heater on for 1.5 hours at max 10.
Checked batteries at 12:30
FB 12.25v
PB 12.15v
RB 12.14v
LB lost 40% of charge in 39 hours.
12:45
Plugged in 240v EHU.
CP 13.2v 16A (should this be 14.4v?)
Front batt 12.14v
Pass Batt 13.24v
Rear Batt 13.24v
Tracker on 13.2 on EHU.
16:00
Tracker on 13.5v
21:00
Tracker on 14.4v
22:00
Tracker on 13.3v
All x3 batts on 13.1v
3rd July 2023 (Monday)
08:45 unplugged EHU
10:00
(10 bars all full on CP)
CP 12.8v -1amp
FB 12.6v
PB 12.8v
RB 12.8v
LB 12.6v with fridge on.
11:45
Max charge is 14.8v 16A
Drove to Kwik Fit on max charge and back.
20:05
CP 12.7v -1amp
(10 bars on battery icon is full)
(Shows 8 bars with 12.7v)
FB 12.6v
PB 12.7v
RB 12.7v
LB 12.5v with fridge on.
23:50
Tracker showing 12.6v
4th July 2023. 09:00
CP 12.7v -1amp (8 blue bars)
FB 12.5v
PB 12.7v
RB 12.7v
21:30
CP 12.5v -1amp (still 8 bars on display panel ?)
FB 12.45v
PB 12.5v
RB 12.5v
LB 12.3v with fridge on.
5th July 2023. 09:00
CP 12.4v -1amp (6 blue bars)
FB 12.3v
PB 12.4v
RB 12.4v
LB 12.2v with fridge on.
21:30
CP 12.3v -1amp (6 blue bars)
FB 12.3v
PB 12.3v
RB 12.3v
6th July 2023. 09:00 outside temp 14 degrees.
CP 12.1v -1amp (6 blue bars)
FB 12.3v
PB 12.2v
RB 12.2v
21:30
CP 12.1v -1amp (4 blue bars)
FB 12.2v
PB 12.2v
RB 12.2v
LB 12.0v with fridge on.
7th July 2023. 09:00 outside temp 20 degrees.
CP 12.1v -1amp (3 blue bars)
FB 12.2v
PB 12.1v
RB 12.1v
12.00
Called VW Droitwich.
Spoke with Tech for California’s
He said, 5 days for good lesuire batteries for running the fridge.
But starter shouldn’t have any draw at all. Over 5 days the specs should only have a 0.03v drop.
And the EHU does NOT charge the battery.
So I don’t understand why my starter is charging from EHU ?
Was 12.1v Sunday. After 20 hours charge, it went to 12.6v
He said it might need investigating.
But to pull fuses from lazerlamp fuse holders.
14:00
Pulled lazerlamp fuses from starter motor battery.
Plug into EHU.
Monitor starter battery for another 5 days.
8th July 2023.
16:00 - outside temp 20 degrees.
Still plugged in
CP 13.0v -3amp (10 blue bars) fridge is on. 28 degrees inside Cali.
FB 13.1v
PB 13.2v
RB 13.2v
LB 13.0v with fridge on.
16:15 unplugged EHU.
Starter is 100% being charged from EHU.
But the relay isn’t clicking in when on EHU.
So how does it charge the starter motor battery ??
9th July 2023. 09:00 outside temp 20 degrees.
CP 12.7v -3amp (10 blue bars) fridge is on. 20 degrees inside Cali.
FB 12.6v
PB 12.7v
RB 12.7v
10th July 2023. 09:00 outside temp 17 degrees.
CP 12.5v -1amp (8 blue bars) fridge is on. 20 degrees inside Cali.
FB 12.38v
PB 12.45v
RB 12.45v
LB 12.25v with fridge on.
FB 12.6v
PB 12.7v
RB 12.7v
Starter 100% charging on EHU.
FB 12.38v
PB 12.45v
RB 12.45v
Missed 11th too busy.
Drive to Impact metals Rowley Regis and Sainsbury's for fuel.
12th July 2023. 16:00 outside temp 17 degrees.
CP 12.3v -1amp (5 blue bars) fridge is on. 20 degrees inside Cali.
FB 12.4v
PB 12.25v
RB 12.25v
13th July 2023. 20:00 outside temp 17 degrees.
CP 12.2v -1amp (4 blue bars) fridge is on. 20 degrees inside Cali.
FB 12.26v
PB 12.2v
RB 12.2v
LB 12.0v with fridge on. -4amps.
14th July 2023. 09:15 outside temp 18 degrees.
CP 12.0v -1amp (4 blue bars) fridge is on. 10 degrees inside Cali.
FB 12.2v
PB 12.0v
RB 12.0v
LB 11.9v with fridge on. -4amps.
10:00 Plugged into EHU
15th July 2023.
Left to charge for 48 hours.
16th July 2023. 11:15 outside temp 18 degrees.
CP 12.8v -1amp (10 blue bars) fridge is on. 10 degrees inside Cali.
FB 12.6v
PB 13.1v
RB 13.1v
LB - switched fridge off.
So starter battery only charging to 12.6v (95%) on EHU ?
Then after 5 days / 120hours at 12.2v (60%)State of charge.
I don’t have confidence in the starter battery. Losing 35% of charge in 5days.
Not if leaving it in a car park for 10 days.
Nothing is plugged into the starter motor battery.
Removed fuses from Lazer lamps.
Tested twice with lazerlamp fuses in and without.
Same result.
To be continued.
Can’t remove Tracker, as it has its own battery (8th July 2023. Lesuire batteries loom to be working absolutely fine. Charging and discharging whilst fridge on. 5 days of fridge on #3)
S7 tracker connected to Lesuire batterys as the App follows and tracks real time and increases on EHU.
Put fridge on #3
Says 12.5v -4 amps.
Start batt 12.5v
Pass Batt 12.5v
Rear Batt 12.5v
CP 12.3v -1A
Front batt 12.3v
Pass Batt 12.4v
Rear Batt 12.4v
CP 12.2v -1amp
FB 12.18v
PB 12.2v
RB 12.2v
10:30 to 12:00
FB 12.25v
PB 12.15v
RB 12.14v
12:45
Front batt 12.14v
Pass Batt 13.24v
Rear Batt 13.24v
16:00
Tracker on 13.5v
21:00
Tracker on 14.4v
22:00
Tracker on 13.3v
08:45 unplugged EHU
10:00
CP 12.8v -1amp
FB 12.6v
PB 12.8v
RB 12.8v
11:45
20:05
CP 12.7v -1amp
FB 12.6v
PB 12.7v
RB 12.7v
23:50
FB 12.5v
PB 12.7v
RB 12.7v
21:30
FB 12.45v
PB 12.5v
RB 12.5v
FB 12.3v
PB 12.4v
RB 12.4v
21:30
FB 12.3v
PB 12.3v
RB 12.3v
FB 12.3v
PB 12.2v
RB 12.2v
21:30
FB 12.2v
PB 12.2v
RB 12.2v
FB 12.2v
PB 12.1v
RB 12.1v
12.00
14:00
Plug into EHU.
8th July 2023.
Still plugged in
FB 13.1v
PB 13.2v
RB 13.2v
FB 12.6v
PB 12.7v
RB 12.7v
FB 12.38v
PB 12.45v
RB 12.45v
FB 12.6v
PB 12.7v
RB 12.7v
FB 12.38v
PB 12.45v
RB 12.45v
FB 12.4v
PB 12.25v
RB 12.25v
FB 12.26v
PB 12.2v
RB 12.2v
FB 12.2v
PB 12.0v
RB 12.0v
15th July 2023.
FB 12.6v
PB 13.1v
RB 13.1v
Same result.
To be continued.
