What are you thinking would be the best way of resolving? It can’t be right, can it?Collected mine today and it's the same. It requires three arms to tuck it up and close the flap at the same time!
In our van it’s a one-women job! We have our set jobs and the roof down plus shutter closing is my wife’s while I sort out the hook up (as soon as the roof is closed). A dab of Autoglym Vinyl & Rubber cleaner on a cloth, ran along the shutter channel every few months, helps it to glide closed with no problems. I keep an eye on the canvas while closing and check the lid’s fully down.Its a tight fit, find its a 2 person job to get shutter closed, gently folding roof, so does not jam shutter.
This is what we do and 90% of the time it works.We rented one with the new pop top material and the guy we rented it from advised us to partially close the blind just before it flops… not sure it is officially correct to do this but it was his van and it worked great. Was concerned it created less room for air to escape but it did avoid any wrestling with the fabric.
fitted a bungee on mine and it’s fab for stopping catching in the scissors but also great at pulling in the front material when lowering. I find that it does now all fold and flop at the front but is pulled towards the back so easy to shut the shutter door.Pop top roof material at front hangs down so a can’t shut the concertina roof flap. Is this normal? Do I need a bungee, or does the roof have an issue?
That’s what we did as well for the first few months. However we had the canvas pull away from the roof channel, and while you can’t be sure about these things, I suspected the bungee didn’t help. We’ve not fitted it since. Anyone want a nearly new bungee ??!I noticed that with the bungee round the bellows
That’s a bit worrying! Anyone else had same problem? I may try slackening mine off a littleThat’s what we did as well for the first few months. However we had the canvas pull away from the roof channel, and while you can’t be sure about these things, I suspected the bungee didn’t help. We’ve not fitted it since. Anyone want a nearly new bungee ??!
You need to tuck it in as it comes down.Pop top roof material at front hangs down so a can’t shut the concertina roof flap. Is this normal? Do I need a bungee, or does the roof have an issue?
A bungee is completely unnecessary as long as you make sure you have a door or window open when closing the poptop.That’s a bit worrying! Anyone else had same problem? I may try slackening mine off a little
It’s normal like the others say. You’ll get use to it. I pull the main bit down at 90% closed and fold the sides in as neat as possible. When pulling the shutter closed pull the bellows towards the back of the van as you slide it closed, you’ll get use to itPop top roof material at front hangs down so a can’t shut the concertina roof flap. Is this normal? Do I need a bungee, or does the roof have an issue?
