You have a T6.1.Hi .
Another question from a newbie.
Does anyone know how to operate the remote fob ?
I press my heater button and nothing happens .
Thanks in advance
Yes works via control panel , the vehicle in only a few weeks old so hopefully won’t be a battery issue.Does the heater work using the control panel ?
Try a new battery in the fob.
I do not think this is possible. I'm sure this question has been asked before or someone tried to get a replacement because the fob was lost.Is it possible to purchase a 2nd remote fob as a spare?
Not sure it’s been mention but I found this out while messing the other day. It is right that when you turn the heater on using the fob, it operates the Heat Immediately function. However, you can also use it to switch off the Heat Continuously function that you’ve switched on via the control panel. Handy when you want to leave the heater on until you get warm in bed then switch it off.You have a T6.1.
Be aware of the Following.
Using the Remote activates Heat Immediate. Parking Heater fires up and will run for a maximum 2 hrs. Then switch off. The Remote will not work again until the vehicle has been driven for a few miles.
Heat Continuous is activated from the Control Panel and will run the Parking Heater 24/7 or for any time interval.
What happens if you switch it off via the fob while having the heater on Heat Immediately? Can your then switch the heater back on without driving (since you didn't use the 2 hour limit)?Not sure it’s been mention but I found this out while messing the other day. It is right that when you turn the heater on using the fob, it operates the Heat Immediately function. However, you can also use it to switch off the Heat Continuously function that you’ve switched on via the control panel. Handy when you want to leave the heater on until you get warm in bed then switch it off.
It is my understanding that the two hour limit only relates to the Heat Immediately option. The Heat Continuously option doesn’t have a time limit. This is supported by the user manual. However, what I haven’t tried is whether, if the two hour limit is hit on Heat Immediately option, it turns off the whole heating function and you need to move the van even to use Heat Continuously. You would hope not but I can’t rule it out.What happens if you switch it off via the fob while having the heater on Heat Immediately? Can your then switch the heater back on without driving (since you didn't use the 2 hour limit)?![]()
As a direct answer to this question, I believe you would be able to switch the heater back on, in either mode, without moving the van as the two hour limit hasn’t been reached.What happens if you switch it off via the fob while having the heater on Heat Immediately? Can your then switch the heater back on without driving (since you didn't use the 2 hour limit)?![]()
