Cali Sound System
OooOooTheMonkey
OooOooTheMonkey
Winchester
T6.1 Ocean 204
Hi all
I can’t find a definitive answer to this using the search. Does the Cali sound system work off the engine battery or the leisure battery? I’m looking for a way to listen to music in the Cali whilst chilling out camping but don’t want to drain the main battery…
Thanks!
Ben
Hi all
Thanks!
Ben
Engine battery.
On previous models a few members have rewired to run off Leisure. Still switches off after 20 mins or so.
If you are on EHU should not be a problem as from T5.1 on, by unintended consequence, and by design, I believe on the T6.1, the engine battery is trickle charged when Leisure are fully charged.
Most people have used standalone Bluetooth speakers etc.
Engine battery.
Ah ok super, thank you
Hi all
Thanks!
Ben
As @WelshGas says. We have a bluetooth speaker and use for music. Have a Flip 6. Cracking size and sound. For radio we just used the phone and internal speakers or Bluetooth one. We protect the engine battery now as much as we can. Even on EHU, with a 6.1 and a solar trickle charge! Once bitten…
I had to replace the original radio in my 2008 Cali several years ago, and took it to a VW van specialist in Andover. He installed a great DAB radio and satnav, but he also installed a little switch in the glovebox, which enabled you to switch the power for the radio from engine to leisure battery! Genius - maybe they should all have that option!
