Unfortunately out of warranty. Do you know what they replaced and how long it took to replace?Fixed under warranty on our MY21 6.1 Coast![]()
Click on the “ Google “ link below.Unfortunately out of warranty. Do you know what they replaced and how long it took to replace?
Unfortunately out of warranty. Do you know what they replaced and how long it took to replaceFixed under warranty on our MY21 6.1 Coast![]()
The Part Number is in Post 4.Thanks fairly confident it's a spring that's broken in the catch, so replacing lid wouldn't help. Ideally need to find someway to replace spring or catch.
Unfortunately it's a t6.1 and the catch is in the trim underneath the lid, not in the actual lid.The Part Number is in Post 4.
Have you been to the local VW parts department. With your VIN they should be able to locate the part.Unfortunately it's a t6.1 and the catch is in the trim underneath the lid, not in the actual lid.
We're on holiday in Germany at the moment, I'll try that as soon as we get back.Thanks.Have you been to the local VW parts department. With your VIN they should be able to locate the part.
Unfortunately LLL Parts doesn't have a complete Parts catalogue for the T6.1 as yet.
Called in at the local dealers, they have 3 in stock in this country. Purchased one for 47 pounds, should arrive Thursday. They have given me a breakdown of the kitchen parts and photos of the part, the fun will start finding out how to replace the old one.We're on holiday in Germany at the moment, I'll try that as soon as we get back.Thanks.
By any chance do you have the part number for the T6.1?Success replacing the button. Fairly straightforward, you need Allen and torx screwdriver bits and a glass sucker to help pull the fridge up. Roof up and bed up remove fridge lid including hinges. Unplug leads from bottom of fridge. Remove 3 screws from each side of fridge. Attach your sucker to base of fridge and pull. It's a tight fit but will come out. There is one lead that stays attached. Lay the fridge to one side and using a trim removal tool force the button out. Push the new button in and reverse the procedure. All should be well again.
Thanks so much for that!!!We have found the receipt for the part from October 23. It is S W7LA 068 769 N/STOCK BUTTON Total 48.72 pounds Inc vat . Ordered from my local vw van centre.
