AL-at-the-wheel
- Messages
- 3
- Location
- Aberdeenshire
Hello everyone,
This is my first post, so please excuse if this question has been asked previously?
I took ownership of a Grand California 600 in September 2023, and I’ve had a few issues so far, certainly a topic for another discussion!
So, this weekend, I was away in the van and the weather has turned rather chilly, with the outside temperature getting down to -5 Degrees C overnight. I had the heating (Truma Combi D6E) on overnight but it switched off and I woke up to find the cabin temperature around 10 Degrees C, when I went to restart the heating I seen that the water tank had been emptied, due to the frost protection valve triggering.
I am aware of the control panel issues from other posts, and the frost protection valve temperature threshold but I was surprised that it functioned given the cabin temperature!?
On investigation I found, local to the valve, a ~ 1” wide hole drilled right through the floor, to the underside of the van, allowing freezing cold air into the space under the rear seat, and I suspect chilling the valve to trip? In your experience has anyone seen this before, and what would the purpose be, if not drilled in error?
Also, has anyone replaced their Truma CP plus control panel with a new iNet X panel?
Thanks for your help.
Al
Al
