One of the problems with aluminium is that you can bend it once, but it will most likely break when you bend it the second time. The upper side is stretched, and the underside is shortened. If you bend it back the other way, the underside can't stretch anymore, and will tear.The alu roof is very lightweight & easy to bend, so probably looks worse than it is. Local body shop should be able to get it back into shape fairly easily.
What a nightmare.Tears were shed.....View attachment 121959
This is something I will never dream of happening to me.
Bikes with such wide handles are indeed not really fitted for the tailgate bike rack.
I hope you can find a solution.
It isWhat a nightmare.
Is that mtb on a bike arm?
Bravo. Looks far better than I would have expected. Perhaps you dodged a bullet there.Thanks all. In this instance it was the only time I've not put the bikes on myself.
We had 2 hours to do an emergency campsite flood evacuation in the Lake District so I'd dealt with the awning, kayak, child, equipment etc whilst the husband put the bikes on.
We got it to the second site fine and I opened the roof without problem. Not sure how it opened without problem?
When packing away from out second site however, I checked the roof twice as I lowered it, as I always do from the front end of the vehicle. I'd totally forgot the bikes hadn't been put on as I would usually.
The roof made all the usual sounds on the final close and I didn't suspect anything until I stepped out to check. My heart broke.
I managed to re open it and remove the bikes. Surprisingly, it closed just fine, enabling me to drive home just fine
I'm a gold/silversmith which is a helpful skill and this is how it looks now after a bit of malleting!
Not sure yet if it will be water tight but a lesson has been learned.....
... I'll put the bikes on myself next time! View attachment 121982
Me too. I really did fear the worst and had visions of being rescued on a low-loader to get home. It's not perfect but I'll see how it goes now and maybe get it looked at at some point. Needless to say, hubby is in the dog-house!Bravo. Looks far better than I would have expected. Perhaps you dodged a bullet there.
I'm guessing the long term challenge will be the paint starting to flake and the bare metal may start to corrode.Me too. I really did fear the worst and had visions of being rescued on a low-loader to get home. It's not perfect but I'll see how it goes now and maybe get it looked at at some point. Needless to say, hubby is in the dog-house!
You've done an excellent job with that.I'm a gold/silversmith which is a helpful skill and this is how it looks now after a bit of malleting!
If he knows whats good for him, he'll be secretly looking at inventory in your favourite shop.Me too. I really did fear the worst and had visions of being rescued on a low-loader to get home. It's not perfect but I'll see how it goes now and maybe get it looked at at some point. Needless to say, hubby is in the dog-house!
Your repair is amazing, like nothing ever happened.Thanks all. In this instance it was the only time I've not put the bikes on myself.
All I can see is a slight dimple that could be easily pulled out by a PDR specialist and the rear crease not being perfectly symmetrical both sides. Brilliant result I would say.Your repair is amazing, like nothing ever happened.
That’s an amazing job you have done! Looks like you have the curve of the roof spot on. Let’s hope it’s watertight so you can avoid a new roof and the accompanying new leaking bellows!Thanks all. In this instance it was the only time I've not put the bikes on myself.
Bravo!!Thanks all. In this instance it was the only time I've not put the bikes on myself.
Great advice, and worth doing if only to avoid such a nasty surprise.You can just spin the handle bars parallel to the frame - just need an Allen key, takes a few seconds. Also makes loading other bikes easier to load, as stops one bikes bars fouling on anothers seat post.
They certainly end up with character I do love that with the older vans.Best story ever...it is brilliant you fixed it.
Makes the van even more special in my book. I had an old T2 camper and that had all sorts of adventures where we drove it into bollards, wired up the valves on the heaters, bodged up the throttle pedal that had fallen off on the way back from Spain...resprayed it at the side of the road, each panel a different colour to save cash...loved that van![]()
VW partsIf he knows whats good for him, he'll be secretly looking at inventory in your favourite shop.
If It wasn't before, it is now!Great advice, and worth doing if only to avoid such a nasty surprise.
And a brilliant bit of malleting too, if that is a word.
