Stargazing
Aaaah right - I'm not so clued up on the T5.The OP has a T5. Different socket to the T6.1.
Out of curiosity, what prompted VW to change to the 3 pin UK socket on subsequent variants?
Used once for charging the electric toothbrush when off grid.I’ve seen an adaptor on Amazon https://www.amazon.co.uk/dp/B07SXH3JT6?tag=unique09f-21 which allows use of the socket and intrigued to read what you guys use it for.
The 230v on the side of the kitchen? Out of reach?I use the inverter socket for my Coffee grinder. All my other equipments are charge via either the usb or 12v sockets, as I find the 230V outlet a bit out of reach.
I think the T6.1 inverter supports up to 300W. My previous T5.1 was only 150W. My wife can now use her hair straightners without the need for electric hook-up. A game-changer as far as I'm concerned!I’ve seen an adaptor on Amazon https://www.amazon.co.uk/dp/B07SXH3JT6?tag=unique09f-21 which allows use of the socket and intrigued to read what you guys use it for.
No, not really.The socket is integral with the inverter.
Me tooI use a 50w plug in insect deterrent. Perfect fit. Never have any creepy crawlers.
Yep - The wife uses it for the GHDsI think the T6.1 inverter supports up to 300W. My previous T5.1 was only 150W. My wife can now use her hair straightners without the need for electric hook-up. A game-changer as far as I'm concerned!
If I put my California on EHU, the motor battery gets topped up as well.I’m currently topping up the leisure batteries whilst on EHU on the driveway and I’m using Welshgases method of using a charger in the kitchen socket to charge the motor battery, via the cigarette lighter.
Just pondering, would the inverter do this?? Could the cali charge its own motor battery via the inverter?
Very inefficient. BUT you can connect a leisure battery powered 12v socket to the dashboard starter battery powered 12v socket.I’m currently topping up the leisure batteries whilst on EHU on the driveway and I’m using Welshgases method of using a charger in the kitchen socket to charge the motor battery, via the cigarette lighter.
Maybe you should try this adaption.T6.1. I don't use the inverter socket because it's rubbish. The UK plugs fall out. It's useless. £70k of vehicle and they can't get that right.
On EHU I have a 3-way adapter.
Off EHU I use my EcoFlow battery thingy.
The forum doesn’t let me see your profile, which model do you have?If I put my California on EHU, the motor battery gets topped up as well.
No need for me to put an extra charger on the motor battery.
