EHU Flap
  • Thread starter California_Clarky
  • Start date
California_Clarky
California_Clarky
Southampton
T6.1 Ocean 204
I have an issue with the flap on my EHU I. That it won’t stay shut and flaps in the wind when driving there is no sign of any damage- is this covered under warranty?
Have you tried pushing left and right bottom? If I just let mine drop down, it won't close either.
You really have to push both sides to make sure it closes.
Otherwise, if there is no sign of damage, and your van is less than 2 years old, ask your VW dealer if this is covered under warranty.
If not, glue some small round magnets on the flap, and put some metal strips opposite of the magnets. This should keep it closed.
This trick must be somewhere on this forum.
hi which part is it please- my Camper is only just over 2 years old - will try the dealer in the morning
Hopefully your dealer will replace free of charge under warranty - good luck.
I put velcro tape on mine; it stays shut now
I've tried the magnetic tape option and just need to test it, hopeful as I'd rather not be rewiring stuff unless absolutely necessary. Thanks
onlyneeds a little extra push and a soft click.. to confirm it is properly closed.
I fitted two neodymium magnets to mine, I'll post the thread
7 years on still working 100%
Post #14
Mine did that after a very hot few days in France, I put a little Velcro on it.
Thanks team, I got some magnetic tape from amazon and have put a few pieces on, just need to get out and test it, most likely at the weekend, I will report back. Appreciate all of your help.
Just had the same problem, 3 years old van - flapping around on the motorway despite me stopping twice to close it. I have put a little square of Velcro (the rough side) on each bottom corner of the plastic housing and now it closes much more securely, hopefully will do the trick!
