Little owl1963
You are massively over thinking things.So auxillary coolant heater if blows at windscreen below 7 degrees will clear ice / snow as says in manual ?
Yes, sort of. The box enables the automatic function of the Auxiliary Coolant Heater that you (and many others) are describing, the one that works with the running engine in cold weather.Understood, but for that auxillary coolant heater to work.
As I keep mentioning , but not 1 person has referred to it ?
Were the lower radio console is , go to vehicle settings.
There you will find supplementry heater option , a square box that you either TICK or Untick .
I presume this either enables or disables the auxillary coolant heater ??
Correct or not ?
So when the coolant heater kicks in below 7 degrees , an blows at windscreen .
It's actually the normal engine heater producing the heat ??
With the aid of the auxillary coolant heater?
The Auxiliary Coolant Heater can also be chosen in the CU menu, instead of Ventilate or Auxiliary Air Heater. These are essentially the 3 options you have highlighted from the manual in your post #45.
If you chose this option, the "heat immediately" (typically via the remote control) would start the Auxiliary Coolant Heater instead of the Air Heater. You would use this to pre-heat the coolant and defrost the windshield prior to driving off.
Everybody knows it's there, every body just leaves ion the factory default, everybody's heater works on a cold morning. Why would anyone bother changing it?Andy , have you looked in radio dash control panel ?
Under vehicle settings , supplentry heater
The SQUARE TICK BOX , no one is ever mentioning this ?
Don't think anyone knows its there?
I don't have a UK spec Ocean, but on mine the remote control starts up whichever option was selected last in the CU. The Coolant Heater (called Wasserstandheizung in mine) is one of those options. When I engage the system with my remote when it is set to Coolant Heater, I can clearly hear the diesel pump clicking, this at 15° outside temperature. The Air Cooler in this scenario remains idle.No it doesn't, you are going to confuse @Little owl1963 even more.
On a UK spec Ocean the remote control starts up "heat immediately" or "ventilate". Ventilate just starts the dashboard fans. Heat immediately starts up the air heater & blows hot air out of the B pillar vents.
Without translating the linked document its difficult to see exactly what it is saying, but the diagrams for all modes show hot air coming out of the B pillar vents - thats what the Air heater is attached to.
