Mid life crisis Cali Swamper!
I should note that my van is much heavier than a Cali and this makes a difference. With fully loaded water and diesel tanks and all my gear I’m driving around at 3.2T weight. Anything less than 3.5 bar cold and I could feel it via the suspension and pedals and see more bulge in the sidewalls than I was comfortable with.
In a Cali you could theoretically go with lower Tyre pressure for the same result. Just need to know your vans weight and adjust accordingly.
Many will say just use the pressure on the door card sticker. Mine say 2.4 bar. That is totally unrealistic with the change in Tyre dimensions as well as the build of the Falken Tyre. These have 3 ply Duraspec sidewalls for more durability off-road and can handle/require more pressure for street use. Of course when going off-road you’d want to air down depending on the surface (sand, gravel, mud)
That's a good point about the weight. Given my van is a Beach and we only travel 2-up my current pressures are probably about right. The wheel/tyre shop suggested 46PSI as a starting point.
What is the best pressure to run Falken Wildpeak 235/65/17s at? I have them all at 48PSI (cold).
I think I’m going to keep them on all year, they’re great for the single track roads about here. Does anyone know the going rate for gloss black 18” Springfields and tyres?
Sounds about right for a reinforced AT tyre. I go 50psi on my KO2’s for general driving but like Webbah my van is over 3t when fully loaded. Had the van on snow a little while back and didn’t feel the need to drop the pressure for on road driving.
Is that fully loaded with deer & salmon you hunted with nothing but your cunning and a tent peg?
I’ve just done this.
235/55R18 BFG Trail Terrain on Delta Klassik B rims.
I’m not convinced it’s for me. (Coming from 275/35R20)
I’ve not had chance to check the tyre pressures yet but my initial observations are that the steering is now really light vs the 20’s and the ride quality is no different.
I think maybe it needs raising a little or going back to standard height.
Having AT tyres on a lowered van feels a bit like wearing timberland boots with a suit.
I’m in half a mind to just stick all seasons on my 20’s and go back to that.
c14c700a70baf212d64a2fd8993bb55b.dng
6bb6df1132bd795f767217c8efe0dff8.dng
7b24f0a3c8a08f2e59c8ba484636b404.dng
3027ff751be84cff7a7d8ba063135eeb.dng
b3e5b4b4f04bed8c8200292667118856.dng
Not sure about Trail Terrains on a lowered van, I tend to agree with your suit and Timberlands analogy (made me chuckle).
Is that the latest self actuating Starlink on the top?
If those Delta Klassiks had been 17” I would have bitten your arm off.
Lovely wheels. I’ve been eyeballing for awhile.
A longish Terranger video (all in German) but my main take out is the new Ford looks like it will make a good base vehicle for a Swamper build. An off road mode in AWD and torque converter auto box are advantages over the T6.1 4motion.
Providing of course they have sorted the engines!
What is/was the problem with Ford engines? just the ones used in the vans? genuine question, just curious
My friend who works for a company with 100s of VW Transporters switched to Ford Rangers when the VW T6 went out last year. They claim that the Ford engines will last about 50.000km and then need replacement.
The timing belt is inside the engine and lubricated by oil. They are supposed to last 10 years but the reality is very different.as contaminants in the oil can degrade the belt much quicker. It can’t be visually inspected and changing the belt is very expensive as most of the engine has to be disassembled.
Ah, I know that is/was a problem with the Citroen (Stellantis) diesel engines. Is Ford still sourcing diesel engines from Stellantis then? I thought they had their own range now.
I've already been adviced from multiple sources to not touch those engines with a barge pole, including from a mechanic that works at a Citroen/Peugeot dealer (family friend)
It’s not easy to find out what engines Ford and VW are using in the new partnership. Neither manufacturer are going to admit that there was an inherent problem with the wet belt design but it would seem bad practice to have not addressed it for the new vans. I note that VW have offered a 5 year (or 124,000 miles) warranty on the new 'T7' which is almost certainly designed in part to reassure VW buyers that are put ff by historical Ford engine problems.
I have no problem buying a 7 year old T6 but wouldn't want to buy a 7 year old "wet belt" Vw in the future. I know VW aren't perfect but this engine down the line could decimate used values and reputation, IMO of course.
I don’t know all the engines affected, but it does certainly affect the Focus, Fiesta and Transit. Citroen/Peugeot engines also have them and the Toyota Proace I believe. Personally, I would not consider any car with a wet belt.
Do we know for sure that Ford/VW are using wet belt engines in the collab? I can’t find any definitive confirmation that they are.
L
pchmlk
pchmlk
kurienp
kurienp
kevin drury
Alied
Alied
G
Gemima0818
G
